Old 09-01-2015, 10:11 PM   #1
GT777
Question Black water flush line check valve stuck.
On my '12 Georgetown 337DS when water is supplied to my black water flush system I get a large leak at the supply line fitting connecting to what I believe is a clear check valve containing a spring and float assembly. This is a new problem so I believe the valve has become faulty. It is located under the bathroom sink with easy access. Can anyone help with the real name of this part and can it be it be cleaned/lubricated/returned to normal service? Anyone else have this problem? Thanks
GT777 is offline   Reply With Quote
Old 09-01-2015, 10:43 PM   #2
Left Coast
Lots of problems with plastic ones......can get brass ones thru HD or Lowes
Old 09-01-2015, 11:22 PM   #3
GT777
Thanks Bob, I'll check them out. USAF
Old 09-01-2015, 11:42 PM   #4
You can also delete it and just add an anti siphon to the end of the hose at the flush fitting. Many have done this.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-02-2015, 04:55 AM   #5
fonzie's Avatar
This is what you are looking for:
Bronze Vacuum Breaker with Check Valve
http://www.amazon.com/JR-Products-57.../dp/B0095TD5S6
Fonzie
black, black water, water
