10-20-2016, 03:29 PM
Black water flush problem
So dumping the tank on my 2015 Surveyor 292RETS I hook up the hose to the black water flush and nothing happens. Am I forgetting to do something?
10-20-2016, 03:34 PM
There have been several reports here of the back-flow/anti-siphon valve in the tank flush line being installed backwards from the factory.
It is 'usually' located near the underneath of the sink in the bath.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-20-2016, 03:50 PM
Looked under the sink. Not there. Any other areas?
10-20-2016, 06:49 PM
Try following the line from the back side of the outside connection for the flush.
Depending on the unit, sometimes you can see where the lines go.
If so, the outside connection will first go to the back-flow/anti-siphon valve, then to the tank. Usually a black plastic valve.
10-20-2016, 07:02 PM
I'll have to do that when it's light out. The under body is all covered so it shall be an adventure
10-20-2016, 07:03 PM
Canadian Member
The antisiphon valve should be installed several inches above the inlet immediately inside. The hose goes up to the valve and then down to the black tank.
Here's a picture of mine except the black plastic antisiphon valve has been replaced with a grey elbow by the previous owner. The plastic valves are known to break. Sorry the picture is on its side.
In your floor plan, it looks like the black tank flush port is on the wall behind the kitchen counter so have a look in that cabinet.
10-20-2016, 07:24 PM
Attachment 123522
Do you have a specific link to the layout?
10-20-2016, 07:27 PM
Attachment 123522
Do you have a link for the layout?
10-20-2016, 07:50 PM
Canadian Member
I just found pictures of the unit online. On those pictures, the flush port is inside the pass through (on the rear wall) and under the bathroom which would be the wall behind the kitchen counter.
http://www.midamericarv.com/rv/carth...rveyor+292rets
10-20-2016, 07:51 PM
Okay thank you. I'll look into it in the am
10-20-2016, 07:52 PM
Turn the water on.
[emoji16]
10-21-2016, 07:48 AM
You will be looking for something like this...
10-21-2016, 08:28 AM
When I used mine the first time I thought it wasn't working but after about 3 min (hooked up and pressurized) I could hear it working and water coming out the dump pipe. I found mine behind the entertainment center just above where my power comes in.
Retired Navy
2016 Flagstaff 26 FKWS
10-21-2016, 08:41 AM
They like to Hide them! Here is another hiding place,behind the Toilet closet! Ours was Broken/leaking the 1st time we used it,Major work to Dismantle and "Cut a Door" just to repair/replace the Valve and Clean up the Mess! Youroo!!
10-23-2016, 07:33 AM
Originally Posted by 325BH
Turn the water on.
[emoji16]
That was my first thought
10-27-2016, 08:53 AM
I noticed when I went to winterize the system, some water on the floor under the sink area coming from the vacuum break. I did flush out the tanks thoroughly at the CG and see some drips of water around the vac break. Does this mean it's bad? How do you test them? Can it be cleaned and reinstalled? Boy howdy are they pricey . I see Valterra and JR product make them. Either one will cost you about $50 before you're done with the freight and tax. Any experience?
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
10-27-2016, 11:55 AM
Canadian Member
The only way to test them is to use them and see if they are leaking, unless you want to rig up something to pressure test with air.
I bought this inexpensive replacement valve from HD to use on the hose at the inlet port.
Everbilt 3/4 in. Hose Bibb Vacuum Breaker-VACBFPZ4EB - The Home Depot
Of course, you'll also need to replace the original black plastic anitsiphon valve with a 90° bend.
10-27-2016, 12:03 PM
Mine was seeping, so I just removed it completely and eliminated about 5-6' of tubing and hooked the hose directly to the tank from the inlet which has a check valve in it from the factory.
