Black water Grey Water Tanks
OK, I own a 2004 Georgetown 326DS. This is our 5th year camping in it. No problems of any kind until this last trip. We were only out for 4 days. When we got home, I noticed the Black Tank gauge was registering full but the Grey Tank was registering empty. It's usually the other way around. So I went to drain and flush the holding tanks and very little water drained from the Grey Tank. So....after draining both tanks, I took the water hose in side and ran several gallons of water into the Black Tank through the toilet, then drained the Black Tank. Then took the hose to the kitchen sink and ran several gallons of water into the Grey Tank. When I went to dump the Grey Tank, no water came out. So I pulled the Blank Tank valve and several gallons of water came out. I went through this process 2 more times, just to be sure. Seems all my waste water is going to the Black Tank only. I don't expect anyone to troubleshoot this through the Forum. Just trying to figure out how this could be happening. If you've seen this before, I would appreciate hearing what caused the problem. Sorry for the long post. Just trying to explain the problem fully. Thanks!!!
hatchet
