Old 08-18-2016, 02:28 PM   #21
Replacing the valve is chap and fairly easy. Even with working valves, I still use the Valterra external screw-on valve, just as insurance. After watching someone else get covered in black tank sludge, when their valve quit working, I vowed to never have that happen to me.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat 4X4 6.4 Diesel
42 nights camping in 2015
61 nights in 2016 (still not enough!)
ben31 is offline   Reply With Quote
Old 08-18-2016, 03:43 PM   #22
Originally Posted by jtaylor1920 View Post
Sure sounds like a valve not closing all the way. As a short term stop gap you might pick one of these up to at least save you from the unpleasant surprise.
https://www.amazon.com/gp/aw/d/B000B...vAL&ref=plSrch
Yes, get this valve, it eliminates nasty surprises.
2017 Dynamax REV 24RB
Delco Bobby is offline   Reply With Quote
Old 08-18-2016, 03:50 PM   #23
swbouton's Avatar
CWMB called me today and said to being the unit in. That's about 2.5 hours each way, but I want the valve fixed, so I'm doing it.
I ordered the Valterra T58 Twist-On Waste Valve yesterday and I'll receive it tomorrow. Cheap insurance!
2014 Cedar Creek Silverback 33RL
2008 Dodge 3500 6.7L Diesel, Quad Cab, 4x4, dually, long bed.
Steve & Pat, "Diesel" the Boxer, and "Molly" the Scotty
_______________
Bought camper 7/14/16
2016: 9 Nights camping
swbouton is offline   Reply With Quote
Old 08-18-2016, 03:54 PM   #24
Best of luck. Hoping it gets repaired to your satisfaction.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-19-2016, 05:21 AM   #25
DouglasReid's Avatar
I wish I knew more about all this!!!
Thank you all for your help.
You WILL know much more about this when you are finished solving the trouble.
Then you can advise the next poster of what worked for you and how to accomplish the fix.
Id put in my two cents but it wold not be anything that has not already been said here in this thread.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 08-19-2016, 08:23 AM   #26
Having done hundreds of repairs on holding tanks and valves , that is not normal. Whom ever works on your unit will find the slide valve seal either damaged or most likely they will find tissue caught in the slider groove preventing the valve from sealing.
hillsdaletc is offline   Reply With Quote
Old 08-19-2016, 08:42 AM   #27
Maybe pull up as close as you can to the main walk in entrance, pull your valve open, and show them the "normal leakage" they spoke of ?
JK - Hope they take care of it for you !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 08-19-2016, 09:25 AM   #28
Wolverine 1945's Avatar
You can't find someone closer to fix that for you ???
After what CW told you,,, It would be a Cold Day you know where before I would ever call them again !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-19-2016, 11:38 AM   #29
swbouton's Avatar
Good point! It's not worth taking a full day and about 250 miles round trip just to get them to repair a valve they should have repaired before I took possession.
I can deal with the black water problem using the Valtera T58, then I can find someone else to repair or replace the faulty valve at a more convenient location and time.
_______________
Old 08-20-2016, 07:54 AM   #30
The Valtera T58 looks like a very easy fix,,, as long as there is room for one !!!
black, black water, leak, water, water leak
