Old 08-20-2016, 12:03 PM   #31
indybp57's Avatar
Obviously you want the valve fixed, but also consider adding a clear elbow where the slinky hooks up. Then you can see anything that might be waiting to surprise you when you remove the cap.
Sent from my 9020A using Tapatalk
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:578/10
indybp57 is offline   Reply With Quote
Old 08-21-2016, 06:28 AM   #32
Wolverine 1945's Avatar
Again you have to have room to add all this extra stuff ???
I think if I were to try to add a valve & an clear elbow to our Sunseeker,,, I would be past the opening where the hose comes in !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-21-2016, 07:43 AM   #33
Mr. Dan's Avatar
When I had a valve leaking, I found that there wasn't enough of the center wire sticking out of the cable wrapping/sheath to allow enough movement to close the valve. I had to trim at least 1/2" of the outer sheath off to get enough inner wire 'travel' to close the valve.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 54; booked = 12
Old 08-22-2016, 05:33 PM   #34
indybp57's Avatar
You don't 'have' to do anything. Just a suggestion to the OP, cause as he found out s____ does happen. If your valve is on the outside space is not an issue.
2013 Roo 183
Old 08-23-2016, 08:26 AM   #35
Your absolute right Indy,,, but many of us have valves inside a compartment !!!
Our old Flagstaff TT,,, the dump valves were so low I can not believe we never ripped then off !!! At times they almost touched the ground !!!
Old 08-23-2016, 08:34 AM   #36
Hi,
My drain outlet is pretty close to the side of the trailer, and after I added a Valterra blade valve for extra protection, there was even less room.
So I don't leave the transparent fitting on continuously. I store it in the same container I use for the grey plastic elbow fitting that fits up to the end of my hose.
And yes, I wonder how I ever really knew what was going on during a tank dump before I had the transparent fitting.
FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is online now   Reply With Quote
black, black water, leak, water, water leak
