Old 05-17-2011, 04:53 PM   #1
miavia's Avatar
Send a message via MSN to miavia
black water lever
Once again I need to ask for some help. The black water lever will not go in all the way after I emptied it hence when left all fluids leaks out, leaving the tank dry. I have pushed will all my might.... I am a petite lady but pretty strong. I can not for the life of me close it completely. Any ideas why and how can I fix this. I am always careful to empty when full and I flush the black tank after every pull. Should I ask a strong man to push it in all the way or might it cause a bigger problem? If someone out there could advise me what to do I would sure appreciate it.My unit is a Cedar Creek 2009 RD5S and it is in a stationary position in a rv park on a lake. Sooo bringing in for repairs is near impossible. All ideas excepted and appreciated. Thank you I donít know where I would be without this wonderful support sight.
Mia
miavia is offline   Reply With Quote
Old 05-17-2011, 05:16 PM   #2
They do get stiff to operate after a while. There is such a thing at RV parts and accessories departments as "Dump Valve Lube" . Have never used it myself, but might be worth a try.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 05-17-2011, 05:22 PM   #3
onetonford's Avatar
You might have a seal that has rolled because it was dried out if you get somebody to force it would only damage it more you might have to have the valve dissassbled and a new seal installed.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-17-2011, 06:29 PM   #4
sherdep's Avatar
if you know for sure it is emptied out you could pull the piece apart - it has 4 bolts holding it together in a sandwich type configuration and check the seal - if the seal is damaged - I do know you can replace that piece from camping world.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
black water
