Old 02-02-2018, 07:28 PM   #1
Black Water Sewer Pipe
All, my new TT came with a starter kit. This kit came with a brown sewer pipe that has a connector on one side that I assume connects to the trailer. The other end has no connector and is just the bare end of the brown corregated platic pipe. I was told that I should be able to drop this into the sewer hookups at most parks. Is this true? What is the best sewer line to buy and what is an ideal length...10, 15 or 20 ft? What a simple effective way to store the black water stuff in the storage area? Thanks!
DSBATCHELDER is offline   Reply With Quote
Old 02-02-2018, 07:34 PM   #2
BandJCarm's Avatar
Throw it away.
Valterra Viper. OR Rhino. Get the detachable ends. Find a place to store separately from anything else.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 02-02-2018, 07:47 PM   #3
You want something like this:
It screws into the campgrounds pipe like this:
Here's a one piece version:
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-02-2018, 08:07 PM   #4
Iíve been getting by with 20í of RhinoFlex and a clear 45 degree twist on elbow.
https://www.amazon.com/Camco-RhinoFL.../dp/B00C5RBRA8
Start with this and add what you think you will need.
Iím going to get a twist on (bayonet) valve before we start this season.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 02-02-2018, 08:20 PM   #5
dbledan's Avatar
X2.
This was the one I found that had everything already attached greased and ready to go. Open box and plug in.
How much hose depends on where your drain is and if you need a Y adaptor for a second connection.
Note that some states (az I believe) require a screw on connector and some a rubber donut.
dbledan is online now   Reply With Quote
Old 02-02-2018, 08:32 PM   #6
The RhinoFlex is plug and play but itís a good idea to make sure the collars that hold the hose to the fittings are tight. Some people have complained about leaking. I made sure mine were tight and Iíve had no problems.
Old 02-03-2018, 01:27 PM   #7
This is similar to what i have. I keep the hose in the back bumper -
perfect fit but be sure to wash it out first (air dry if you have time) before you place in there! Elbow won't fit so have to store that somewhere else.
https://www.amazon.com/Camco-RhinoFL..._&dpSrc=detail
Stacia is offline   Reply With Quote
Old 02-03-2018, 01:31 PM   #8
jtesta1's Avatar
I keep my hose in a large Rubbermaid container with air holes cut in the side to stop mold .It goes into the pickup bed
jtesta1 is offline   Reply With Quote
Old 02-03-2018, 02:35 PM   #9
360true's Avatar
I recently added an 8' length of 5" square PVC fencing with end caps to store my slinky stinky. Click image for larger version
2014 Georgetown 378 XL
Toyota Prius on dolly.
Full time since 2014
360true is offline   Reply With Quote
Old 02-03-2018, 03:07 PM   #10
DouglasReid's Avatar
[QUOTE=Stacia;1722515]This is similar to what i have. I keep the hose in the back bumper -
We use a plastic storage container to keep things separate. One for sewer connections, one for fresh water hoses and another to put electrical cords. No cross contamination this way. They all store in our pass through.
We have a Rhino 20' sewer hose that stays in the sewer connection box. Most times it is long enough. BUT, JUST IN CASE, Do not throw away that other hose, you may need it. I store one of them in my rear bumper for emergencies (have only needed it twice but those two times it was a God Send!
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
black, black water, water
