If that is where your black tank flush goes into the tank? Then you will first drain your black tank, then remove the screws and pry off the fitting. It will have a tank rinser attached that is what sprays the water in your black tank. On my previous camper it used a silicone gasket. Get a new black tank flush and install using directions provided with part. Hope this helps.
