Old 05-17-2019, 10:34 PM   #1
Black Water Tank Flusher won’t work
I have a 2005 Forest River Cardinal 5th wheel. When I drain my black water tank and try to flush the tank with the water hose, but water want go in the tank. The water line goes straight up. What am I doing wrong or not doing right?
orabun is offline   Reply With Quote
Old 05-18-2019, 12:07 AM   #2
What do you mean by "water line goes straight up"?
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 05-18-2019, 12:08 AM   #3
Retired Old Fart
dward51's Avatar
What brand/model flusher? And what do you mean by "the water line goes straight up"? Can you post a photo?
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
Old 05-18-2019, 05:22 AM   #4
bubbles's Avatar
Here is a typical factory install of a black tank flush system. It's self contained. The vacuum breaker/check valve could be located in any of several places (under vanity/behind shower/in washer dryer closet etc.). It will be located at least 6" above the toilet rim height though wherever it is. This is a typical install and your valve may look different (clear/black/different shape etc.). Your issue may be a clogged tank nozzle/inoperative valve/valve installed backwards etc..
Old 05-18-2019, 12:54 PM   #5
Telstar's Avatar
I also have a 2095 Cardinal. The water line goes up to where the check valve is located behind the shower faucet. Last year when my sprayer got clogged I found it was the spray head in the tank. Although some have had success in cleaning it with chemicals I choose to replace it. I bought a spinner type at Camping World. I did a hose test of the two in the front yard and found the spinner type much more efficient. As for replacing the sprayer I removed the screws holding down the storage floor and slid the plywood out the passenger side. This gave me full access to the tank without having to mess with the under belly sheeting. .
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
black, black water, flush, tank, water, water tank
