Old 10-18-2010, 07:54 AM   #1
Black water tank pressurizing?
hello all, new to the forum. We have a 2007 Cardinal and after emptying our black water tank this past weekend (and using the power flush to rinse it out), we are experiencing an issue with our toilet where when you flush, an air bubble appears when you depress the foot pedal. Even with the black water valve opened, it is still acting like the tank is not venting properly. Has anyone experienced something like this? Does anyone know if it's possible for the vent to get clogged? Any information will be greatly welcomed. Thank you
2004 Chevy 3500 Silverado Dually w/Duramax
2007 Forest River Cardinal
bdyates is offline   Reply With Quote
Old 10-18-2010, 03:37 PM   #2
It can .but not very common. You may just want to run a hose to your vent up top & flush the vent stack with dump open if you can? See if that helps.
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
Old 10-18-2010, 04:10 PM   #3
NWJeeper's Avatar
X2
Ed & Wendy
www.nwjeepn.com
Old 10-20-2010, 01:39 PM   #4
thanks camprat and NWJeeper for your ideas. As it turns out (and I am embarassed to report), all it was was a blockage at the bottom of the pipe beneath the toilet. Depsite us using the tank's power flusher, I guess we did not let it run long enough and it left a buildup behind. I borrowed my fathers flushing wand and gave it a thorough flushing - everything is working fine now.
Old 10-20-2010, 04:34 PM   #5
Glad to see it all work out. Happy camping!
2010 wildcat 31ts
05 Ford F350 SD PS
Old 10-20-2010, 04:40 PM   #6
tmmar's Avatar
x2 !!!
Tom and Margaret
2014 Berkshire 390bh-60
black water
