Old 06-18-2015, 05:21 AM   #11
Post to rv.net. Someone from camping world will respond. I would think this is a camping world problem not a forest river problem.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 06-18-2015, 05:22 AM   #12
Something really Smells about this (Purchase) from C/W! It sounds more like a (As Is) rather than a (No Warranty)! The total issue is NOT F/R. Used it is between (Buyer and C/W)! If the Vent pipe is also NOT lined up sounds like a (Shifting/Sliding ) tank! Youroo!!
Old 06-18-2015, 06:34 AM   #13
Oakman's Avatar
That is a great idea. Camping World, Good Sam, RV.NET, Trailer Life Magazine, are all under the same corporate umbrella with Marcus Lemonis as the CEO.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-18-2015, 06:45 AM   #14
Dave Lyon's Avatar
Yep....your issue is with the seller not Forest River.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-18-2015, 07:13 AM   #15
Boss Ox & Drovergirl
oxcamper's Avatar
OP is not about Camping World or FR, it's about not being able to use the toilet.
What happens if you look 'down the hole' with the water off? Can you push a stick, broom handle, garden hose into the tank? Can you see or put something all the way down into the tank?
You don't mention what happens when you open the dump valve, or if you have a black tank nozzle for cleaning.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-18-2015, 07:18 AM   #16
TURBS's Avatar
If I'm reading correctly, the toilet and the tank are connected? Correct?
The issue is the pipe angles from the toilet to the tank? Correct?
The other issue is you say water runs to to the tank via the angled pipe but you say solids do not? Correct?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-18-2015, 07:26 AM   #17
Originally Posted by silentpartner View Post
I agree about not buying from Camping World again. There actually is a hole, but it's about 4" over from where it should be - it's not directly under the toilet opening. Another hole cannot be cut because the holding tank dump pipe is directly underneath.
Sounds pretty clear! Youroo!!
Old 06-18-2015, 07:48 AM   #18
The PROFIT GUY. Ok, something sounds out of "joint." OP, there had to be a warranty, even a short period one, on even a used unit, unless you waived it in the deal.
Old 06-18-2015, 07:58 AM   #19
Witch Doctor's Avatar
It is still a CW problem, they can not sell you a unit that will not work. Warranty or no warranty they still have to make sure that things work or make you sign a disclaimer that they told you of this problem. If they will not help take it back to the dealer and park it with big lemons all over it, I bet they will fix it then. Now this is worst BS I have heard from a dealer.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-18-2015, 08:07 AM   #20
Dealers sold (FEMA) trailers all the time,and they sure as hell could not be used for LOTs of things! They had (S/N and Titles)! Sold (AS IS)! Youroo!! I have seen Many converted FEMAs at C/G around the USA!
black, black water, tank, water, water tank
