Old 01-11-2017, 09:59 AM   #1
Black water valve issue
I have a 2015 Rockwood Ultra Lite
The black water valve works its way open as I travel down the road. When I get to my destination I have a mess while hooking up.
The past few times I have duck taped so it won't work open.
Can this be adjusted or do I need to replace?
Mr. Mike 45 is offline   Reply With Quote
Old 01-11-2017, 10:08 AM   #2
Though it won't solve your problem, it will definitely mitigate it until you do:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I purchased one of these just for the possibility of what you are experiencing. Inexpensive and an easy install.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 01-11-2017, 10:16 AM   #3
Jim34RL's Avatar
X2 on the extra valve! I have one on my Cedar Creek 34RL also.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 01-11-2017, 10:20 AM   #4
Remove blade valve and inspect as well as the seals! Replace if necessary! Youroo!!
Old 01-11-2017, 10:36 AM   #5
What windsurfdog said. No muss, no fuss.
Pipeman is offline   Reply With Quote
Old 01-11-2017, 02:18 PM   #6
DKRITTER's Avatar
Absolutely agree, this is a must have for every RV.
I'm still using the one from 3 trailers ago.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
DKRITTER is offline   Reply With Quote
Old 01-11-2017, 02:29 PM   #7
Back to the OP's question, you should be able to disassemble the blade valve and have a look at what might be going on in there. Usually the force of the sealing rings on either side of the blade are enough that it takes a healthy push/pull to move the blade. If the forces of vibration or wind while going down the road opens yours, something is wrong.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 01-11-2017, 02:57 PM   #8
A very annoying problem indeed. I had this same problem on my previous tt. Both the black and grey valves would work open while travelling. I never bothered to try and find out why. I simply got some short (6") bungies and looped over the handle. Problem solved. Never opened again unexpectedly.
Good luck.
hunterrick is offline   Reply With Quote
Old 01-11-2017, 04:42 PM   #9
Dazed & Confused
M&K Hoffman's Avatar
I agree with youroo and 5picker, pull apart, inspect and replace what is needed. The valve should have some resistance when pulled open and it is better to fix the problem rather than slap on a Band-Aid, IMHO.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
M&K Hoffman is offline   Reply With Quote
Old 01-12-2017, 10:04 AM   #10
Vince and Charlette's Avatar
As soon as I saw Windsurfdog's link, I decided to get one and keep it in my tool box. Thanks again for this Forum and the help we all get from each other...invaluable!
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 01-12-2017, 10:16 AM   #11
I leave mine on all the time.
Old 01-12-2017, 12:07 PM   #12
DKRITTER's Avatar
All three of the valves leak on my Cedar Creek.
They have from the day I brought my trailer home and they have been dismantled more than once but never the less they continue to leak.
I have had to use the twist-on valve on my Cedar Creek because I don't like pouring out a fair amount liquid on me and or the ground when I take the cap off thefore it is a necessity.
Former Owner of
black, black water, valve, water
