Old 10-19-2012, 11:48 AM   #11
Lynkage's Avatar
Originally Posted by Fire Instructor View Post
......... plus it makes a splatter mess.
I hang a hand towel over my faucets to keep that in check.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 10-19-2012, 11:51 AM   #12
TURBS's Avatar
I'm not saying 40 psi is right or wrong just stating what's in my manual.
Do as you please.
Turbs
Old 10-19-2012, 12:04 PM   #13
AquaMan's Avatar
If you have your faucets open, and your bottom drains it won't matter how much air pressure you use. You'll never be able to put enough air into the lines to build up any type of pressure to blow a line apart, unless you're using a commercial air compressor, and then you would have to have special fittings to accept the cfm it would take to bust a line. I have compressors from 40hp to battery operated, and I run 90-120psi from the compressor into the water line, and the back pressure guage barely moves.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 10-19-2012, 12:05 PM   #14
Originally Posted by jt1920 View Post
Our winters are generally mild here in the Pacific Northwest so we camp throughout the year and I don't do a full winterization of our rig. I drain the water heater, empty and remove the water filter, open all taps and pour RV antifreeze into each sink, the shower and my tanks after every trip. This year I'd like to take it a step further and blow my lines out but I want to be careful and not use too much air pressure. For those of you that use air to clear your lines what PSI do you set your air compressor to?
Thanks in advance for your help.
If you have a Flagstaff you need to use no more then 25 PSI, all others can use 40-45 Just picking at you Turbo. I was going to assign you an acronym by using your new "Free Advice Giver" name, but once I shortened just using the first letters it just wasn't right
Seriously to the OP, it's perfectly safe to 40PSI. Here are some links if you don't believe us:
Winterizing with Air
Country RV - RV Quick Tips
Americamp RV Sales
Len & Cheri is offline   Reply With Quote
Old 10-19-2012, 12:10 PM   #15
TURBS's Avatar
Lol f.a.g
Good one!
Nope I upgraded to a wonderfull sabre!
It's all good!
Turbs
Old 10-19-2012, 12:47 PM   #16
Lynkage's Avatar
Originally Posted by f1100turbo View Post
Lol f.a.g
Good one!
It's all good!
Turbs
Now that was funny!!
Shane & Antoinette
