Old 07-04-2014, 07:48 AM   #11
Originally Posted by crunchman12001 View Post
So.... You are saying remove the valve from under the sink and connect the 2 pipes together with an "elbow"????
Then use what type of exterior valve?
Do you have a pic and a link to a suitable replacement?
Thank you,
crunchman
Look up (Valtera Hydroflush) they have the garden hose anti-siphon valve (pictured). I found mine at a Hardware store. I also have (Male threaded Plugs) on ALL of my outside fittings,the (Rubber Push Caps) are a Joke,and to keep Clean! Youroo!!
Old 07-04-2014, 07:52 AM   #12
Plain Old Member
What I was always thinking. When you consider the tiny jet holes, location of the nozzle in the tank, the vent, routing or our pex (above tank level after nozzle), there is just no real way it'll siphon. Been gutting them for 7 campers and never a problem, even without the external anti siphon valve.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-04-2014, 08:02 AM   #13
Same way here,but the screw on/off (Anti-siphon Valve) is just for (Compliance to Pluming Codes)? Youroo!! I have never had or seen (Black Crap) running down the side of a RV flush port,that was PROPERLY installed above the Black tank! Youroo!!
Old 07-04-2014, 12:38 PM   #14
crunchman12001's Avatar
Originally Posted by Herk7769 View Post
You of course can do what you want, but I would spend the 40 bucks and get a correct replacement.
I have no problem spending the $40, was not sure if there was a better way?
2015 F-250 FX4
Old 07-04-2014, 02:58 PM   #15
rattleNsmoke's Avatar
I ended up ordering mine directly from the manufacturer, Lakeview RV Supplies. $35 including UPS shipping. It solved my leakage problem but as others have stated, they've replaced more than one. Next time around maybe I'll try the chop N' drop and be done with it.
rattleNsmoke is offline   Reply With Quote
Old 07-04-2014, 07:34 PM   #16
Herk7769's Avatar
Originally Posted by OldCoot View Post
Lou, you are confusing this redneck, my black tank flush is above the black tank and has a back flow preventer on it. Does the black tank roof vent prevent the syphon?
They are talking about removing the vacuum break and only using a check valve at the outside connection when flushing. The roof vent will not prevent a siphon if the water gets into the hose while traveling wind can siphon the water out just like it sucks the water through the fresh tank vent.
HAM CALLSIGN - KC3FFW
Old 07-05-2014, 09:23 AM   #17
bubbles's Avatar
First off the backflow preventer has nothing to do with vacuum. It is basically a mechanical stopper switch that is spring loaded to the reverse flow (closed) position and is only actuated to allow flow in only one direction when pressure (water/air) is applied against the spring which is attached to the stopper. If the above statement was true I believe the Turbo Flush aftermarket system would not work. It does work, I have used it. The factory installed system routes the tubing up into the interior of the unit (mine is routed at least 5 feet above the black tank) where the backflow preventer is installed (don't think the preventer is required in my installation with the routing of the tubing being as is). The fresh water tank will syphon as stated but it is the vent that the syphoning takes place (tank is otherwise a closed system). A simple loop in the vent tubing stopped this in my coach. There is, to me, much a do about this subject and a lot of it is urban legend and speculation and I'm probably guilty of enhancing that myself. Anyway, I think I am correct with my input. Maybe not. I'm done.
