Old 06-27-2014, 11:27 AM   #1
rattleNsmoke's Avatar
Blown out anti-siphon valve?
I have a new anti-siphon valve on order from Lakeview RV supply in Texas. I noticed water pouring from around the two cold water lines leading up thru the basement into the cabinet below the bathroom sink. I'm hoping the check valve is the culprit altho the valve itself looks fine. Maybe they just get hung up and let water and don't let the water bypass to the tank. I realize there have been threads regarding cutting the valve out and using two 90's and a section of 1/2" pex clamped in place, but the dealers have said NO it's not advisable. Don't mind the ramblings. I guess I'm just thinking aloud here.
rattleNsmoke is offline   Reply With Quote
Old 07-03-2014, 05:02 AM   #2
arpipeliner's Avatar
Look down about 21 post below and u will get ur answer. Don't know how to make the link to it.
arpipeliner is offline   Reply With Quote
Old 07-04-2014, 06:08 AM   #3
Herk7769's Avatar
Anti-siphon/back flow preventer required to keep black water in the tank and out of your hose (and off the roads) when the flusher is not in use.
If the valve is bad, you can replace it with a new one (or a different type); but do not bypass it.
HAM CALLSIGN - KC3FFW
Old 07-04-2014, 06:36 AM   #4
crunchman12001's Avatar
Mine is bad too. I tried to use the black tank flush and it poured water under the bathroom sink. I still need to buy one though.
I did research the ATMOSPHERIC VACUUM BREAKER/
CHECK VALVE
(571 Vac Chk)
"bottom of page"
I see them for sale on this Amazon link.
crunchman
2015 F-250 FX4
Old 07-04-2014, 07:21 AM   #5
To (Eliminate Floods Inside) your RV from these (Cheap made/not price Backflow/Check valves), replace with (flow thru fitting)! Now just use a (Screw on garden hose backflow adapter on the (OUTSIDE) hose fitting, (The one that says-BLACK TANK FLUSH)! Now when and if it LEAKS,(Who cares) its OUTSIDE! Your unit your choice? Youroo!!
Old 07-04-2014, 07:35 AM   #6
So.... You are saying remove the valve from under the sink and connect the 2 pipes together with an "elbow"????
Then use what type of exterior valve?
Do you have a pic and a link to a suitable replacement?
Thank you,
crunchman
2015 F-250 FX4
Old 07-04-2014, 07:37 AM   #7
Herk7769's Avatar
Just never drive with the black tank fluid level above the turbo nozzle.
One of the reasons it is a vacuum break in addition to a check valve is the "Anti-Siphon" part of its name.
If the outside cover should leak or come off, the wind flowing over the hose connection will create a Venturi suction and actually suck the black water out of your tank and down the side of your camper.
The Vacuum break will allow cabin air to enter the pipe to the outside to prevent that.
Old 07-04-2014, 07:39 AM   #8
Herk7769's Avatar
Thank you,
crunchman
You of course can do what you want, but I would spend the 40 bucks and get a correct replacement.
Old 07-04-2014, 07:41 AM   #9
Plain Old Member
I just use the external. Had one leak in wall, and 2 under bathroom sinks. Our SB did it first use. I've cut every one of them out as they are garbage. Not worth the risk. The ones you can put at the external inlet can be found at lowes or HD.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-04-2014, 07:45 AM   #10
Originally Posted by Herk7769 View Post
Just never drive with the black tank fluid level above the turbo nozzle. One of the reasons it is a vacuum break in addition to a check valve is the "Anti-Siphon" part of its name. If the outside cover should leak or come off, the wind flowing over the hose connection will create a Venturi suction and actually suck the black water out of your tank and down the side of your camper. The Vacuum break will allow cabin air to enter the pipe to the outside to prevent that.
Lou, you are confusing this redneck, my black tank flush is above the black tank and has a back flow preventer on it. Does the black tank roof vent prevent the syphon?
