Old 04-21-2012, 07:02 PM   #1
Brand New Shower Drain not Draining
Hi there, I bought my Chapparal 279 BHS last fall and it was already winterized. We have just started to drain the lines of the antifreeze and were working on the shower lines, when I noticed that the shower drain was not draining. Is this something that the dealer did not do? This unit came brand new from the factory, and should not be plugged at all. Just wondering if there is a simple fix that I can do, instead of having to take it to a dealer an hour away. Please help.
Robin Hein is offline   Reply With Quote
Old 04-21-2012, 07:54 PM   #2
okdrifter's Avatar
Is the gray tank full??????
Doug and Carmin
2010 Wildcat 31TS
2008 F-250 King Ranch
okdrifter is offline   Reply With Quote
Old 04-21-2012, 07:57 PM   #3
okdrifter's Avatar
Forgot to say
Doug and Carmin
2010 Wildcat 31TS
Old 04-21-2012, 08:06 PM   #4
No, the grey tank is not full. I wish that was the problem.
Old 04-21-2012, 08:13 PM   #5
okdrifter's Avatar
Is water standing in the shower? Or am I at the wrong drain?
Doug and Carmin
2010 Wildcat 31TS
Old 04-21-2012, 08:16 PM   #6
Herk7769's Avatar
Robin,
Has it been freezing till you started to dewinterize?
Water could have frozen in the trap.
If so be careful that the pipe is not cracked and that water will run into your basement when it thaws out.
What year is it?
Is it "new" new or new to you?
HAM CALLSIGN - KC3FFW
Old 04-22-2012, 09:21 AM   #7
The water sat in the shower for about an hour and slowly drained. The trailer is brand new. I was reading somewhere that it might be the vent that is on the sink drain that might not be opened or something. Just wondering if anyone has ran into this problem.
Old 04-22-2012, 11:08 AM   #8
fonzie's Avatar
Like Herk mentioned, the drain p trap might have been frozen if there was no antifreeze put in. Have you tried to put hot water and see how it drains now? It has been below freezing in your area!
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-22-2012, 01:39 PM   #9
Could trap is clogged from debris when they build the trailer. When I first drained my grey tank, there was a lot wood debris in the tank, that must have come from the drain. Some were wood chunks. Like wood punch holes, etc.
jleon01 is offline   Reply With Quote
Old 04-22-2012, 02:38 PM   #10
Drinkin beer on the beach
Rod Johnson's Avatar
Your drain plug isn't pushed down is it?
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
