09-08-2015, 02:05 PM
Brand New Trailer Brand New plugged toilet
So our 2016 Cherokee 274RK ..... looking down into the toilet I notice there is a plate about 3 inches below where I the toilet drains I can see a spot weld seam
Is this correct ? Should the toilet not drain directly down into the black tank without obstruction ? I had to basically stir a toilet paper backup on this lower plate....seems odd
09-08-2015, 02:16 PM
Georgia Rally Coordinator
Bummer. Don't sound good. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
09-08-2015, 02:34 PM
A pic would help!
09-08-2015, 02:43 PM
Yes - quite odd. The toilet on most TTs empties straight into the black tank because the BT is right against the underside of the floor between the frame rails and there is no vertical room for an offset run like in a 5er. If you can't see the bottom of the black tank through the throne, I would think that would be a problem.
Maybe the hole was not drilled through completely and the disc that should have been pulled out is now a flap still attached at one side. They arrive at assembly with no openings at all and all penetrations are made once installed in the unit.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
09-08-2015, 02:47 PM
Many installations use fittings such as 45 ells and short sections of pipe to direct flow a short distance to the tank. Ideally it's just below but not always, same problem. Best answer use plenty of flush water.
09-09-2015, 12:20 PM
Our grey water valve wouldn't shut last outing, when I opened it up there was a "half circle" of abs from the hole saw stuck in the valve.
Bob
2013 Rockwood 2504
2015 Silverado 1500 4x4 Z71 Double Cab
Diablo and Lew Custom tuned
Tony & Catnis, campin' kitties
09-09-2015, 12:24 PM
does anyone live with a septic system at home? we rarely flush TP in the bowl, there is a wastebasket that accepts used TP and is dumped in the trash regularly... we do the same in the Shamrock toilet... saves lots of problems when dumping
2014 Shamrock 183
09-09-2015, 12:28 PM
You should be using RV TP which is about 1 ply and very dissolve able. Never have issues when using what is recommended. Later RJD
Days camped 2019 62
09-09-2015, 12:29 PM
My sabre does not go straight to the tank, it has Atleast two elbows.
We use plenty of water and have not ever had a black tank issue.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-09-2015, 12:30 PM
I've had a septic at my current location for 13 years!
Toilet paper and all heads right to it!
it's been pumped once.
TURBS
2011 32bhok Sabre
09-09-2015, 12:31 PM
We only use RV paper and sparingly .........guess this is nothing compared to the siding thats letting go ....on both sides
I will post a pic tomorrow
09-09-2015, 12:33 PM
most TP will dissolve quickly. To test it put some in a jar with water let it sit for a couple of minutes and then shake the jar. If the TP breaks apart you should be OK.
As far as putting the TP in a wast basket, I will stop camping before I will do this.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
yep. lots and lots of water is the trick.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
09-09-2015, 12:59 PM
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
We've been rv'ing for 10 years and have always dropped the TP into the toilet with all the other goodies. We've never had a problem except in the beginning when nobody told us to keep the black water tank drain valve shut until it fills up. That was a nightmare and it only took one time to become an understander of the logistics of these toilets. Once that toilet paper gets to the tank,,,,it pretty well turns into a slurry that is no problem AS LONG AS YOU'RE USING A LOT OF WATER. Lots of water is a black tank's best friend.
09-09-2015, 01:02 PM
TURBS
2011 32bhok Sabre
^^^^^same here^^^^^^
09-09-2015, 01:07 PM
Yeah, so does mine, but the OP has this.
09-09-2015, 01:10 PM
Originally Posted by trbomax
A pic would help!
09-09-2015, 01:53 PM
Have septic at home and use two ply Northern no problems ever. As for the 5er I use 2 ply scotts it is thin and breaks down well. These RV now a days have such small black water tanks Most between 40 to 60 gal not a lot of room for extra heavy paper. My old unit had 100 gal black and I miss it.
09-09-2015, 01:56 PM
Originally Posted by Iwritecode
Yeah - we're all just BS'in in the dark without that.
09-10-2015, 07:49 AM
We have out Septic Tank pumped every 5 or 6 years,,, TP no problem !!!
We do use 1 ply TP in our RV,,, found that years ago the good stuff would plug the potty in our Flagstaff TT !!! They also make a TP Digester ???
