Old 02-21-2018, 01:15 PM   #1
Brand New Trailer Sewage Smell!
Hello!
We just bought a Rockwood Mini. It is our first travel trailer. My husband brought it home Sunday and everything was great. The next morning, however, it had a distinct sewage smell. My daughter said she had accidentally bumped the kitchen sink faucet and about one cup of water came out before she turned it off. We believe this is what initiated the smell into the inside. So, my husband flushed out the tanks and vented the entire trailer. It still smells!!!
Is this normal? I expected to do all the maintenance and cleaning to prevent any odors but why would it smell if nobody had used anything and owned it less than 24 hours?? Will I be fighting this smell the entire time we own it??
HELP!!!!
Sasquatch2 is offline   Reply With Quote
Old 02-21-2018, 01:25 PM   #2
cavie's Avatar
Originally Posted by Sasquatch2 View Post
Hello!
HELP!!!!
Sice you are smelling sewage I have to assume you bought this used but your tittle says brand new so I confused. If new, somebody some where must have had to go. If it was sitting on a lot for a long time the p-traps in your trailer could very well be dry. Many gray water tanks do indeed smell like sewage. If new, you could be smelling some construction materials such as glue and fabric smells that will go away. Run some water, more than a cup, thru all your sink and shower drains. Some air freshener and some open windows should take care if it.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 02-21-2018, 01:46 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
What cavie says is all possible but there is also a chance that one of the pipe joints are either not glued or not even properly inserted. We had the p-trap under the kitchen sink come apart once on a brand new trailer. In your case the only way to find out is to thoroughly inspect every pipe and joint front to back, including the vent pipe on the black tank.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 02-21-2018, 02:12 PM   #4
It is brand new, just off the lot. That is why I don't understand the smell. I didn't know if this is typical until the lines and tanks are flushed out? I assume there is no way to get a visual on the tanks/lines. Or if I should fight the dealership on this and have them look into it.
Old 02-21-2018, 02:15 PM   #5
Ok, good to know. Thanks! We will check out the p trap to make sure everything is secure. I hope it is something simple because I don't really want to drive it back out to the dealer and fight that uphill battle.
Old 02-21-2018, 02:47 PM   #6
ben31's Avatar
Also, ensure there is water in the p-traps.
Since it is new, there really shouldn't be anything in the holding tanks, unless the techs decided to "try" everything on the trailer.
Not for the feint of heart. Do you get the same smell, if you open the toilet valve? If so, then someone likely used it. Also, one of my TTs had a bad seal on the toilet, which let the smell back into the trailer. Dometic actually sent a new toilet to the dealer and they replaced it for me.
Lastly, get the Siphon 360 vent cover(s). They do an excellent job of removing the smells from the tanks, so they don't find their way in elsewhere. I don't know if you'll need two or just one. Our Crusader has all of the tanks going into one vent.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 02-21-2018, 03:11 PM   #7
Just A Member
EDABEUT's Avatar
Is your kitchen sink faucet a pull out sprayer type ??? They have a hose under the sink and when water sits in the hose it gets a sewer smell. When we bought ours new it did this also. Water sat in the hose on the dealer lot for months before we bought it. Factory does water test these units before shipping and will have some water left in them. I had to put a bleach mixture in my fresh water tank and pump it thru system and let it sit for a few days then flush out with clean water to get rid of the smell. I now make sure when we park it for awhile I pull out the sprayer and drain hose.
I have also seen this is our house sink sprayer when water sits in it along time. Something about the hose material makes it smell like sewer.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 02-21-2018, 03:14 PM   #8
Just A Member
EDABEUT's Avatar
Also welcome to the forum
Ed & Brenda
Old 02-21-2018, 03:24 PM   #9
Keystoner's Avatar
Maybe there shouldn't buuut . . . Last fall my sister and brother-in-law switched from a pop-up to a class C. (Having been a girl scout she never hooked up water to the pop up.) I showed them how to winterize it. Since it was a brand new unit I didn't expect about 3 gallons of water and stench to pour out. Fortunately it was only liquid. I think perhaps some salesmen and or customers may not have walked to a functioning restroom.
Keystoner is online now   Reply With Quote
Old 02-21-2018, 03:38 PM   #10
Before you start pulling toilets and replacing roof vents, it is very possible the smell came from the water your daughter ran into the sink.
Often times, untreated well water can smell like rotten eggs/sewer.
You didn't mention how you were using the trailer once you got home.
Were you hooked up to your own city water source or was the pump on when your daughter ran the water?
While I would hope not, it is entirely possible the dealer could have put some bad water in the fresh tank when they tested the plumbing for leaks.
Have you tried to run any additional water from the faucet and sample the smell.
Have you drained any water from the fresh tank drain to sample?
You really should drain and sanitize the fresh tank anyway on a new unit.
Too many unanswered questions for us to give you the exact cause.
Days Camped: '16=46 '17=30 '18=51 '19=36
trailer
