Old 12-29-2012, 03:26 PM   #1
Brass Tee with back flow preventer
In need of a Brass T, 1/2m on all sides, with a back flow. Does anybody know where one can be purchased. Will take plastic if I have 2.
Portagie1968 is offline   Reply With Quote
Old 12-29-2012, 04:12 PM   #2
rattleNsmoke's Avatar
Have you tried a plumbing supply store?
rattleNsmoke is offline   Reply With Quote
Old 12-29-2012, 04:47 PM   #3
realebill's Avatar
found this....
Watts 9D-M3 9D-1/2-M3. Watts Backflow Preventer. Dual Check Valves with Intermediate Atmospheric Vent
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is online now   Reply With Quote
Old 12-29-2012, 04:57 PM   #4
hotrodj125's Avatar
In my 40 years of plumbing, i have never seen a "T" with male threads on all 3 ends, but, maybe at Menards or HomeDepot in the plumbing Dept in the Brass Fitting section, you might find one or be able to make one up and put a backflow preventer on one end. Good luck
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 12-29-2012, 05:46 PM   #5
Hotrod - In my Rv I have 2 of them. They are plastic.
Old 12-29-2012, 08:44 PM   #6
hotrodj125's Avatar
well i'll be jiggered-- yep, prob in rv's or mobile homes this is a common fitting, but never used one in residential or commercial.
Rod & Linda Johnson
Cedar, Minnesota
2012 Columbus 320RS
K-9's Lucy & Lizzie
Old 12-30-2012, 10:04 AM   #7
RVs parts can be a rare bird. I agree. They use stuff that is very hard to find out here.
Old 12-30-2012, 10:33 AM   #8
VinceU's Avatar
If you can't find it, how bout a std female tee w/ 3 close nipples add your check space permitting, assuming yor're working with plastic or Pex piping.
VinceU is online now   Reply With Quote
Old 12-30-2012, 10:38 AM   #9
Vince - That might work. Great suggestion. Need to find one with a check valve in it. 1/2 F threads for the plastic fittings in an RV.
Old 12-30-2012, 11:54 AM   #10
bob213's Avatar
Maybe you could use two of these with a T to make your own.
Camco 23303 1/2" RV Back-Flow Preventer : Amazon.com : Automotive
bob213 is offline   Reply With Quote
