Broke my saintary drain, need advice...
Hello all, I have a 2013 Grey Wolf 28BH
This weekend my sanitary drain encountered a pile of dirt while making a sharp turn and I broke the grey water pipe at the elbow, so I can't just put a splice coupling on it. At the same time the Black water pipe got pulled out of the tank. I was able to reinsert the black water pipe into the tank and tighten it with the existing hose clamp. I was surprised to see the piece that connects to the tank appeared to be a press fit coupling with an o-ring. It was covered with some kind of black sealant goop also, but I think that was more of a just to be sure it doesn't leak measure. My real question here is that I need to replace everything from the waste gate valve back to the grey tank. On the tank there is a 3" to 1.5" reducer. Does anyone know how that attaches to the tank? Is it glued on, or just another press fit arrangement. If it is press fit, where can I get one of those? I've been looking and don't see them as being readily available online. For now I have a temporary repair with a piece of 2" radiator hose and a couple of clamps.
