Old 07-29-2013, 06:39 PM   #1
Broken Black Water Flange
I have a sinking feeling this is a bad one. I bottomed out my 2011 Flagstaff HW27 pop-up and broke the valve lever. That would have been easy to repair but I just learned the flange (I think that's what it is) exiting the tank is broken. See picture. There is a rubber coupling but unfortunately it did not fail first. Is this a tank replacement or can it be repaired?
Mike
Mtn4Mike is offline   Reply With Quote
Old 07-29-2013, 07:16 PM   #2
Based on your pic, I'm thinking "new tank." Unless a new one can be glued to the outside somehow, but I'd be leery of that if I had it done. Maybe someone has has more experience?
rockfordroo is online now   Reply With Quote
Old 07-29-2013, 07:31 PM   #3
Twisty's Avatar
New tank. The fittings will be welded on.
Buying a new tank might not be much fun but imagine a repaired tank failing at the campsite.
Repairing plastic that has been exposed to the elements or "other stuff" is virtually impossible.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 07-29-2013, 07:53 PM   #4
Thanks for the replies. Has anyone ever replaced a black water tank? I assume this is no longer a DIY. Any idea on cost?
Mike
Old 08-09-2013, 02:49 PM   #5
This is ending up to be a DIY. The tank itself isn't too bad regarding cost, $137 + shipping but the dealer says it will be a 5 hour job. The tank is above the plywood floor and below the toilet/shower pan so that needs to come out to get to the tank. Dealer claims about $1000-$1200. I'm pretty comfortable with this type of work so I'm going to do it. Wish me luck!
Mike
Old 08-09-2013, 05:06 PM   #6
Broadway Joe's Avatar
Good luck and take lots of pictures.
Broadway Joe is offline   Reply With Quote
Old 09-08-2013, 10:55 PM   #7
Finally got the new tank. Thought I would share the replacement sequence, which I wish I would have had going into this.
I'll share the problem first.
The toilet and shower tray needs to be removed to access the tank. Here is where I started. I removed the hard walls to get better access.
Here the toilet is removed. I had to cut the vent plumbing to unscrew it from the fittings. Instead of buying all new vent plumbing I used a coupler to fuse it back together when re-assembling. Access to the shower drain plumbing (lower right) is underneath after removing a protective cover. This must be removed to get the shower tray out.
I removed the toilet flange with my DIY tool.
Here I have removed the shower tray. This part sucked. The screws are easy but all that caulking is tough to break loose. I had to remove the towel bar and soap tray to get the shower tray out but no big deal. The new tank is in.
From here it's just reversing the process. This entire process took about 4 hours, including replacing the waste valve and all associated plumbing. Total cost about $300.
I hope this is helpful to someone
Mike
Old 09-08-2013, 11:12 PM   #8
Glad to hear your problem has been repaired, hopefully you can still get to enjoy your Flagstaff this year. Nice job with the repair.
Old 09-08-2013, 11:39 PM   #9
jim44646's Avatar
I repaired my tank with a crack about the same as yours. The product is called Plasti- mend. cost about $50.00. Tanks Been working great. I'm just saying this to let others know there are other alteritives to pulling black tank.
jim44646 is offline   Reply With Quote
Old 09-09-2013, 10:13 AM   #10
Where were you about a month ago? Although I'm not sure I would trust a repair with such an extensive crack. I feel better about it being new. I also added a pipe hanger underneath near the waste valve fastened to the frame which it did not have originally. Probably contributed to the failure
Mike
water, black, black water
