Old 01-03-2020, 11:06 PM   #1
Global Nomad
Scheinin's Avatar
Bug ate hole in my Viper Sewer Hose
I purchase the Viper Sewer Hose Kit because this forum said it was one of the best systems, including the fact that it is crush proof. What I didn't expect was a cicada, in shedding it's shell, gripped on the center portion of the hose and punctured it.
I cannot find a realistic way to patch this hole, while maintaining the ability to compress the hose for storage. Any suggestions?
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 01-04-2020, 11:54 AM   #2
Herk7769's Avatar
I think a 5 minute 2 part Epoxy might work if you work it into the tiny holes before it hardens.
HAM CALLSIGN - KC3FFW
Old 01-04-2020, 06:52 PM   #3
Hoglou's Avatar
Flexsteel liquid.. or liquid elect tape.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-04-2020, 08:43 PM   #4
Global Nomad
Scheinin's Avatar
Thank you, I will try both those methods.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 01-05-2020, 01:43 PM   #5
Be sure to let us know what worked or what you finally did to fix it.
campers302 is offline   Reply With Quote
Old 01-05-2020, 04:35 PM   #6
I love Flex steel. If you are using the spray/liquid, first attach a patch over the hole and let dry. Then use the Flex steel. The tape is a bit thick and may not flex enough to fold the hose as it did when new. Also allow each to "set up time" and make sure that they are firmly pressed onto the hose.
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days,2018- 100 days, 2019- 35 days
RitaB is offline   Reply With Quote
Old 01-05-2020, 09:20 PM   #7
Global Nomad
Scheinin's Avatar
Thank you. I did that, and although it stopped the leak, and plugged the hole, it came undone when I put the hose away, probably because the gray part of the hose is so flexible between the red ridges.
I am next going to try a sealant glue from a hot gun. It was also suggested that I collapse the two red ridges together trapping the hole in between, and glue those ridges together.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 01-05-2020, 11:31 PM   #8
Collapsing and gluing the ridges together sounds like the best suggestion.
A cicada? That's one tough bug. Probably thought your hose was a tree.....
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 01-06-2020, 10:42 AM   #9
Have you by chance been storing Viper hose in the rear bumper tube.
Gary Shastid
2019 Flagstaff Classic Lite 831CLBSS
2014 Ram 2500 Cummins Crew Cab 4x4 with RamBoxes
GlowPlug is offline   Reply With Quote
Old 01-06-2020, 01:00 PM   #10
Tundra 2014
Hose
I have used Shoe Goo and then Gorilla Tape over it. We were in the middle of a 6 week trip. It held for trip and has held for 6 months, still working. Do not cut and try to patch hose w/ a connector, connector is too big for hose.
Tundra 2014 is online now   Reply With Quote
Old 01-06-2020, 09:26 PM   #11
Global Nomad
Scheinin's Avatar
There is no rear bumper tube on a 5th wheel.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 01-06-2020, 09:47 PM   #12
There is no tube on your 5th wheel. A lot of us have a rear bumper.. my 33IK does but it does not have the nice molded rear end like your unit,
2016 Siverback 33IK
Old 01-07-2020, 07:07 AM   #13
Global Nomad
Scheinin's Avatar
Thank you, I should have said on mine. I use a large Rubbermaid container that I can put in all my hoses and hose parts. Very convenient, fits nicely in my basement.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 01-07-2020, 07:23 AM   #14
Capt. Mike's Avatar
With a story as unusual as this one, why don't you contact the manufacturer and tell them your tale of woe, and ask them what you can do to fix the problem? Suggest that there might be a problem that they would want to have their R & D people check out so it doesn't happen to somebody else. They might just give you a new one to foster "customer good will".
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is online now   Reply With Quote
Old 01-07-2020, 08:47 AM   #15
DouglasReid's Avatar
NOT TRUE.....yours may not, but that is not true of ALL 5ers.......
We have a rear bumper that is a 4" square tube, and we store an extra for emergencies pair of cheap drain hoses in it.
We also have caps on it that will not allow any bug larger than a gnat inside the bumper.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 01-07-2020, 01:36 PM   #16
Thought I went "Nutty" without gathering any nuts..
Gary Shastid
Old 01-07-2020, 03:23 PM   #17
Herk7769's Avatar
So, why the question about bumpers was asked is that rust can and will form inside the tube (more or less based on the climate and salt content of the air). That rust and road vibration can wear holes in a sewer hose stored inside.
There is also this potential issue …
ID:	221547   Click image for larger version
Old 01-07-2020, 03:45 PM   #18
PPST Wannabe
kenandterry's Avatar
Nothing wrong in those photos Herk......they’re trolling for their next rig.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 01-07-2020, 05:52 PM   #19
Tundra 2014
Drain Hose
You sure this is not an anti-static ,no tailgating device dragging? LOL
Old 01-07-2020, 07:30 PM   #20
Can't laugh. Upon arriving home from one trip last year, I noticed the stinky slinky door open. Guess what - yes, empty.
AbdRahim is offline   Reply With Quote
