Old 03-31-2013, 08:24 PM   #11
One Happy Camper!
SPPD's Avatar
My previous TT had very detailed instructions on winterizing, but my wifes grandma tossed them when her memory started to go. I followed a internet video instructions, but after draining the wh I put the plug back in. Then I blew out the water lines and all the water dumped into the tank. It could not have been too much water but over the winter it froze and cracked the tank on the bottom. I replaced the wh with a new one by myself and it was a very easy job so no labor charges. When I replaced the wh I also put in a bypass which it did not have originally. It was a 400 dollar mistake. When we got our new TT we had the mechanic show is the winterizing procedures twice just so we were sure nothing changed with the newer unit. You could always ask your dealer to walk you through it once or have them do it and you watch.
Hang in there you are not the first and wont be the last to make this mistake.
Good luck!
SPPD
2013 Palomino SolAire 317 BHSK
Nights Camped YTD: 39
TV: 15 F-250 Crew 6.2 short bed, ProPride Hitch
1995 Jayco Eagle 304 BH sold- March 2013
1978 Nomad 18 sold- April 2005
SPPD is offline   Reply With Quote
Old 03-31-2013, 08:27 PM   #12
As far as the wood trim goes, get ahold of Forest River parts and you should be able to get what you need. I bought several custom sized cabinet doors as well as stiles and rails. You should be able to get what you need and the finish will match your original.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 03-31-2013, 08:28 PM   #13
VinceU's Avatar
Originally Posted by nullvalue View Post
Hmm I'll look into the insurance aspect.. Found a place online that sells the unit for about $320 new/shipped. Why don't these trailers come with any mfg instructions on how to winterize?? As a newbie I was left trying to figure out stuff on the internet.. really sucks.
Anyone have any ideas about replacing the swelled/ruined wood trim?
The heater will need replacing 1. If it is failed and 2. if its a Suburban model. The other guy is Atwood and they will sell you a tank for about 1/2 the price. The way to winterize it is to remove the anode with a socket, all the water will come out that way.
As for wood trim, I'm sure Forest River will sell you the pieces if well documented with photos. Like someone said make sure its the heater and then order what you need heater or tank. It happened to me with my first water heter. Good luck with repairs!
Old 03-31-2013, 09:58 PM   #14
Phat Phrog Stunt Crew
elind's Avatar
I once froze my Atwood water heater 5 years ago. The tank did swell and burst a crack a few inches long. I took it out and had friend with a welding shop hammer it back into shape, then weld it. He charged me $30 for the job.It lasted the next 3 years till I traded the TT in.
The other option was to buy a new tank for $175 vs a 400+ complete heater. Lesson learned.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-31-2013, 10:07 PM   #15
I don't know why everyone insists that the tank needs to be replaced. I would take it out and see where the split is located. It may be an easy fix as elind said. You could then bench test it to make sure everything worked, and you would be good to go.
bakken is offline   Reply With Quote
Old 03-31-2013, 10:08 PM   #16
Thanks for all the help here - I'll be giving Forest River a call tomorrow.
2006 Ford Expedition Eddie Bauer
2013 Salem 26TBUD
nullvalue is offline   Reply With Quote
Old 03-31-2013, 10:10 PM   #17
And as far as the wood goes, being that it is that new of a camper, I would think the factory could supply you with a replacement cabinet, especially if they haven't changed the design for this year.
Old 04-04-2013, 02:13 PM   #18
hotshott's Avatar
You have a new travel trailer and you did not receive any paperwork on how to winterize???? This is a customer service issue. EVERY camper I have ever owned came with manuals for each and every utility, electronics, plumbing, ect...I have owned numerous used and 3 new campers. I have walked out of dealers due to lack of employee knowledge and or bad customer service. Unfortunately, the 6 gallon water heater is an aluminum shell wrapped around a fiberglass liner. It cannot be repaired nor should you flood it with rv anti-freeze as this will destroy the liner.
TT. 2011 Salem Grand Villa.
TV. 2009 F350. Dually, Lariat, Twin Turbo (after market)
w/ stock exhaust and Maramount Easy-flow muffler.
hotshott is offline   Reply With Quote
Old 04-04-2013, 02:18 PM   #19
hotshott's Avatar
Being new to RV'ing I thought I had properly winterized my trailer but apparently I missed an important step - I didn't fully empty my hot water tank. It must have froze and cracked at some point over the winter. I went in it for the first time in a couple months yesterday to find a nice puddle of water on the floor. On top of something broken with the water heater my practically brand new 2013 Salem 26TBUD now has some swelled wood around the base of the kitchen, the finish looks horrible now around the bottom.
So first things first.. do I need to replace the water heater? Is there a chance I can get the tank welded/fixed? I haven't removed it yet so I don't know at this point where the actual leak is. I can't see it coming directly from the fittings so there may be a hole in the under-side of the tank.
Second, what are the chances of being able to order replacement wood for around the base of the kitchen?
Your water heater, unfortunately is not repairable. When next you winterize, DO NOT allow anti freeze into the heater. You will need to drain it and leave it empty. There is a by-pass valve that will allow you to do this. I made an earlier post that was in general to a gentleman that owns a new camper and did not receive any plumbing paper work or any literature on winterizing. I would have left that dealer in a heartbeat.
Old 04-04-2013, 02:26 PM   #20
TURBS's Avatar
Imo the work to get to the "leak" is more work then buying a replacement and getting it going.
I'd be affraid of the repair leaking down the road with expansion and contraction of these units it's a high possibility.
Besides if I leave on a 2 week camping outing and that thing leaks one day into trip my dw would show me the business end of FPOF ! Guaranty THAT!
Replace it and be done.
