Old 11-14-2018, 04:32 PM   #1
Bypass
OK one more dumb question. On my docking station I have two bypass switches. One is for the hot water heater. The other simply says "winterization". I understand what the hot water bypass does. What does the other one bypass? I know its a dumb question but I am new at this. Thanks.
DeltaMud is offline   Reply With Quote
Old 11-14-2018, 04:40 PM   #2
Head Rambler
It would help to know which RV you have and if you could post a picture of the station.
Just a SWAG would be it's to switch the pump from drawing from the fresh water tank to drawing from the antifreeze inlet tube.
Gotta go campin!
Old 11-14-2018, 04:43 PM   #3
bikendan's Avatar
Even though the OP doesn't have his RV info listed in his profile, an older post says he owns a 2018 Primetime Crusader.
Equalizer WDH
Old 11-14-2018, 04:45 PM   #4
That would be correct, Thanks. Specifically, model 315RST. I am going to take a picture now.
Old 11-14-2018, 05:19 PM   #5
These are some pictures. The tee is the backside of the switch. The bottom tube goes to the pump intake. I'm not sure where the other two go. One upstairs and one to the FW tank?
Name:	2018 11 14 059.jpg
ID:	191439   Click image for larger version
Name:	2018 11 14 061.jpg
ID:	191440   Click image for larger version
Name:	2018 11 14 063.jpg
ID:	191441   Click image for larger version
Name:	2018 11 14 064.jpg
Old 11-14-2018, 05:38 PM   #6
attached
Old 11-14-2018, 05:56 PM   #7
Mr. Dan's Avatar
This is correct. The anti-freeze side hose should go to the outside so it can be stuffed into the anti-freeze bottle.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
bypass
