Old 01-03-2019, 04:20 PM   #1
Bypass for hot water heater
2018 forestriver 325 13 wolf pak .looking for the location of bypass valves for hot water tank.anyone know???
tomswolfpack is offline   Reply With Quote
Old 01-03-2019, 04:30 PM   #2
I don't have your model but if a tank type heater (not tankless) they are typically located behind the water heater (accessed from inside the trailer) or in a wet bay. (accessed from outside in the wet bay)
Often times you need to remove a panel, drawer, or open a cabinet to access them when inside. Find the location of your water heater on the outside, then go inside to the corresponding area of the outside location to start your search.
You should be looking for something like this...
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 01-03-2019, 04:57 PM   #3
wmtire's Avatar
5picker has you fixed up, but this thread may offer more pics and valve configurations you may encounter.
NO (OR LUKEWARM) HOT WATER -Please read first
2011 Flagstaff 831 RLBSS
As I've told my kids a hundred zillion times, "Don't exaggerate."
Old 01-03-2019, 05:41 PM   #4
If this is your unit:
https://www.funtownrv.com/product/ne...ck13-772949-26
it appears to be under the shower/bathroom sink. You probably have to access it from the pass through. Look for a panel, probably screwed shut - they like to do that.
I've attached a pic of the various ways they've figured out how to plumb the bypass valves.
2011 Traverse LT, 3.6L, FWD
hot water, water heater, water, heater, bypass
