Old 12-03-2009, 06:01 PM   #1
Question Bypassing Hot Water Heater
New to RV's....need a lil advice on a Sandpiper 365 RLT
Fixin to winterize camper for first time. I understand everything i need to do to winterize a camper other than how to bypass the hot water heater????
I'm what u might call mechanically slow, so pics would really help me.
05 Sandpiper 365 RLT
08 Dodge 2500 6.7 Diesel 4x4
shields71646 is offline   Reply With Quote
Old 12-03-2009, 08:27 PM   #2
milzat's Avatar
The by-pass should looks similar to the photo below. This is a view of the back side of the water heater.
Remember, when the valve knobs line up with the water lines, they are in the open position.
To by-pass the water heater, open the valve on the by-pass line and close the valves on the Hot & Cold lines.
milzat is offline   Reply With Quote
Old 12-04-2009, 06:38 PM   #3
KyDan's Avatar
As shown in the photo above, my trailer only has 2 valves- one
as a bypass and one in the cold water supply.
You might have 3 but I'm guessing you'll just find 2 as in the
photo.
Don't forget to shut off the electric heat and DRAIN the water
heater.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 12-05-2009, 05:20 AM   #4
Mine has 1 valve.Its a 3 way valve located where cold water inlet is in picture,with a bypass line from it to hot water line and check valve at heater.
Dave&Eileen
bdb2047 is offline   Reply With Quote
Old 12-05-2009, 06:40 AM   #5
MtnGuy's Avatar
I had a 1 valve system installed on my Trailmanor (3 way valve) , and now had a 3 valve system on my Surveyor. There is probably no check valve if there is a 3 valve system, but it would be needed on a 1 and 2 valve system.
Old 12-06-2009, 12:45 AM   #6
Thanks for all the help....got it all winterized today
