Old 11-03-2015, 11:00 PM   #1
Adony's Avatar
Campground Sewer Connection
We RV a lot at Washington State campgrounds... They have aniquated sewer connections that are parallel to the ground.. (see picture).. I use a Rhino Flex hose that has a 90 bend at the connection point.. (see picture).. with the attachment on the end of the hose it is extremely difficult to connect and make it stay in the campground sewer connection.. Camco does not make a straight output connection to put on the hose.. so.... what would you use?
ID:	93677   Click image for larger version
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 11-03-2015, 11:23 PM   #2
Take the 90 off and put hose in the hole. Not much else you can do.
RedRollingRoadblock is offline   Reply With Quote
Old 11-04-2015, 12:01 AM   #3
I just put the 90 in and back it up with a big rock or log. most of the ones around the coast and OLYPEN are flush with the ground....
poorbuthappy is offline   Reply With Quote
Old 11-04-2015, 01:41 AM   #4
caper's Avatar
Purchase a cheep hose and fitting to attach to the end of your good hose. The hose only needs to a a foot or two long to go into the hole. (you did say that you visit the state parks on many times. It will be a cheep fix and stop the change of the hose coming loose. Don't forget to wear your gloves when handling sewer lines.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-04-2015, 06:08 AM   #5
Oaklevel's Avatar
X2 or if in a pinch take the fitting off the end of the Rino hose they screw off easily.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
mpg
