Old 11-04-2012, 04:46 PM   #1
HONDAMAN174's Avatar
Camping below freezing
For thanksgiving we are traveling to a new campground that has hook ups but usually gets well into the 20's at night. Has anyone had a problem with the water supply line between the hook up and trailer freezing before?
Just glad to get away
Old 11-04-2012, 04:53 PM   #2
"Don't Tread on Me"
sgtsdj's Avatar
Just get some Heat Tape at your local Lowes. Wrap it around your water hose and plug it in. That will keep the hose from freezing.
Steve J.
Retired VA Law Enforcement
, Good Sams Life Member
Rockwood 8329SS
2002 F-250 7.3 Diesel Powerstroke Powerhouse
Chipped, Bank's Exhaus
t - "Bad to the Bone"
sgtsdj is offline   Reply With Quote
Old 11-06-2012, 09:15 PM   #3
john I
johnemt's Avatar
Dude if your camping in that pop up the water line will be the least of your worries. I know i have done that
John I
2012 Columbus 365RL
2012 Dodge Ram 3500 6.7 cummins
1963 5'2" wife Sheri
johnemt is offline   Reply With Quote
Old 11-06-2012, 09:37 PM   #4
Ha ha. Giving it a try. We've done low 30's dry camping so doing it with hook ups should be better. 3 heaters-check. Heated mattresses-check. Plenty of propane and beer-check. Did I mention that we were going camping? Lol
Old 11-06-2012, 09:40 PM   #5
You'll be fine. What could be more fun? Cold night, big campfire, plenty of beers - sounds like a good time!
crasher is offline   Reply With Quote
Old 11-06-2012, 10:20 PM   #6
SibeTribe's Avatar
Just make sure you disconnect your water hose at night and drain it. I camped last year in Herkimer NY last day the KOA was open and my hose froze, but camper was fine. An hour in the sun defrosted the hose and I cleared it by running water through it. That was in my 21.5 Antigua Hybrid. Would also HIGHLY recommend some liners for your tent ends. I made it through that horrible New England blizzard in Mass with 22" of heart attack snow. 26 degrees both there and in Herkimer. No freezeups. If you have electric, buy a small electric heater. One with auto shut off if it tips over. I have a Sunbeam that's good. Switchable between 750 and 1500 Watts.
Sue & Sibes
2002 Ford Expedition XL
2012 Tracer 2700 RES Touring Edition
4 Trips 70 nights
SibeTribe is offline   Reply With Quote
Old 11-07-2012, 07:03 PM   #7
john I
johnemt's Avatar
sounds like you have a good plan. Have fun any camping is good camping,and always gives good stories to tell
John I
2012 Columbus 365RL
Old 11-07-2012, 07:40 PM   #8
I recommend the disconnect and drain the water hose at night unless you will be in freezing weather all day. I personally would not get the heated tape for just a weekend. Just me, and we stay out of most of the cold in our unit!
ritzyteach is offline   Reply With Quote
Old 11-07-2012, 08:07 PM   #9
SibeTribe's Avatar
for years at my horse farm I would water then detach the hose from the standpipe and drain it. Doing things that way works fine. Rubber hose helps too if you can find one that is OK to use for drinking water.
Sue & Sibes
4 Trips 70 nights
