Old 12-10-2014, 09:56 PM   #11
Ret E-9 Anchor-clanker
donanddona's Avatar
Bought a 25ft heat-tape from lowes $30.00. Foam pipe insulation $15.00. A little left over duct tape.... Not quite the $100.00 but it works!
donanddona is offline   Reply With Quote
Old 12-10-2014, 10:34 PM   #12
bruce10's Avatar
cifw
My tanks are exposed . Do they not freeze if somewhat full? I guess it would have to stay in the 20s for a couple days to freeze 20 or 30 gallons in my tanks enough to bust any thing? Someone mentioned a tank heater. Don't rightly know what that is but will check it out.
bruce10 is offline   Reply With Quote
Old 12-11-2014, 07:27 AM   #13
dcheatwood's Avatar
Sorry Bruce. My rockwood, and many other units, came with attached heating pads for cold weather camping.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 12-11-2014, 11:15 AM   #14
We stay in our trailer, Prime Time Avenger with the extended weather package, for four days in which the weather was below freezing, during a cold front that blew in, and had no problems with fresh water tank and lines freezing. A good test.
utahlucky is offline   Reply With Quote
Old 01-19-2015, 05:24 AM   #15
Just wondering how to find out if my unit has 12vollt tank heating or just 110 ac ,any help 306 toy vengeance 2014
Dana Lance is offline   Reply With Quote
Old 01-19-2015, 02:15 PM   #16
Paradise has arrived!
Paradise115's Avatar
Planning on doing some winter camping next winter. CG turns water off in winter so will have to bring my supply. My question is...if I blow the lines when I leave and add antifreeze will I be ok for two weeks of northern PA weather while I'm gone? The belly is covered but not heated. Have abducted heat vents in the trailer. Don't really want to but should I leave the furnace running while I'm gone for the 2 week intervals? Thanks for your advice!
Southwestern Pennsylvania
Paradise115 is offline   Reply With Quote
Old 01-19-2015, 05:13 PM   #17
[QUOTE=Paradise115;767262]Planning on doing some winter camping next winter. CG turns water off in winter so will have to bring my supply. My question is...if I blow the lines when I leave and add antifreeze will I be ok for two weeks of northern PA weather while I'm gone? The belly is covered but not heated. Have ducted heat vents in the trailer. Don't really want to but should I leave the furnace running while I'm gone for the 2 week intervals? Thanks for your
Old 01-20-2015, 12:00 PM   #18
Fully winterize and then don't worry about the tanks. When I winter camp I take a bottle of antifreeze to flush the toilet for any midnight use, then use the heated campground restroom the rest of the time, including showers. Water is kept in gallon jugs. I keep a dish pan in the kitchen sink to catch any water that might otherwise go down the drain and that gets dumped in the bushes.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
camping
