Old 09-18-2016, 01:53 PM   #11
RV flange is same like residential flange?
2016 Hyper Lite XLR 30HDS
2015 GMC Sierra Denali 3500 DRW
GMCdiesel is offline   Reply With Quote
Old 09-18-2016, 04:42 PM   #12
nomad297's Avatar
Originally Posted by CedarCreekWoody View Post
At a plumbing supply store. It attaches to the old flange, it doesn't replace it. Hence the reason it raises the toilet height.
You buy them at a plumbing supply house. It does not attach to the old closet flange - it is a completely new, differently shaped closet flange than the standard one. You must cut off the old closet flange to install the offset flange. If it is installed properly, it does not raise the toilet height - it connects lower on the vertical pipe leading to the closet flange than a normal closet flange would.
Bruce
Old 09-18-2016, 04:43 PM   #13
nomad297's Avatar
Yes.
Bruce
Old 09-18-2016, 04:51 PM   #14
nomad297's Avatar
Also how do you remove old flange?I guess it will be glued to black tank.
I got all screws out, but can't pull it out.
If you had the years of experience that a good plumber has, you could chip the hub of the closet flange off of the pipe, but that is a true skill that takes practice.
Your waste pipe may be glued to the tank or it may be pushed through a gasket, but if you're having as hard of a time as it sounds like you are, I'd say its glued in. Can you see where it connects to the tank?
Bruce
Old 09-18-2016, 05:55 PM   #15
Multiple styles are available. Study what you have and then review your options at a plumbing supply house.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-18-2016, 06:33 PM   #16
nomad297's Avatar
Please tell me more about these multiple styles. I have been plumbing for 34 years and would sure love to learn something new about my trade.
Bruce
Old 09-18-2016, 08:16 PM   #17
On mine I just turn the flange conter clock wise and then ,I was able to pull it out of of the black tank rubber seal.
Jonol is offline   Reply With Quote
Old 09-22-2016, 08:10 PM   #18
I'll try again Sunday. There is about 1/2" play between floor and flange.I'll try to twist it a little, I am not sure if it is glued to black tank.
Old 09-22-2016, 08:47 PM   #19
Mine was doing that to. It is the top of the black tank that is moving up 1/2 ``
I dont know for sure if it is a rubber seal ?
You have to make the decision!!!
Old 09-25-2016, 11:02 AM   #20
Mine is glued on.I guess I just put old toilet back and live with it.
