Old 09-12-2016, 06:21 PM   #1
Can't figure out how to sanitize
I have a 2016 36CKTS bought this last spring. Shortly after we bought it we started smelling mildew in the water. I installed a 3 filter system and changed out the fresh water hose to no effect. It's so bad now that the smell overpowers soap and laundry detergent.
So obviously I've tried sanitizing with the bleach water solution. One small problem, I can't figure out how to get it into my fresh tank. I'll suck it up through the winterization tube, but then it just sprays right out of whatever fixture I opened to activate the pump.
I assume there's some magic combination of valves I have to open and close, but I can't figure it out.
ID:	120045   Click image for larger version
hebardstravels is offline   Reply With Quote
Old 09-12-2016, 07:18 PM   #2
bubbles's Avatar
I pour the bleach in my hose before connecting to tank fill port. It will enter the tank with the fill water from the house faucet. Do the same thing and fill your holding tank as usual. The longer the hose the more bleach can be inserted at a time. If more bleach is needed just disconnect the hose, drain hose and add more, re-connect and go. Just a way to get it done.
Old 09-12-2016, 07:22 PM   #3
Is the bad smell only hot or both hot and cold?
325BH is online now   Reply With Quote
Old 09-12-2016, 08:32 PM   #4
Both hot and cold, but only a mildew smell
Old 09-12-2016, 08:44 PM   #5
crunchman12001's Avatar
Washer / dryer prep or installed?
2015 F-250 FX4
Old 09-12-2016, 09:06 PM   #6
asquared's Avatar
You might need to sanitize the water heater as well. As stated above, I use a funnel to add the bleach directly through my fresh water hose into the fresh water tank fill and follow it with water through the hose. Using one of theseis very helpful.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-13-2016, 01:15 PM   #7
mike.t's Avatar
https://www.pinterest.com/pin/38843615513304240/
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 09-13-2016, 01:48 PM   #8
BamaBob's Avatar
Proceedure for Sanatizing a Fresh Water Tank
Asquared is correct - those fresh water tank fillers are worth their weight in gold!
However, I think a Cedar Creek uses a manifold similar to a Motorhome...correct?
If so, here is how I do it on our coach:
1. Turn the water heater off and let the water cool (if you have a hot water tank).
2. Dilute 1/4 cup of household bleach for each 15 gallons of tank capacity in to a gallon of water.
3. Using a large funnel, and a 2' section of fresh water hose, add the chlorine/water solution to the water tank. (Never pour straight bleach into the RV fresh water tank!)
4. Fill the fresh water tank to capacity
5. One faucet at a time, let the chlorinated water run through them for one or two minutes. You should be able to smell the chlorine. (Make sure you are using the water pump and not an external water supply.) Don't forget to run the chlorinated water through your outside shower.
6. Top off the RV fresh water tank and let stand for at least three hours over night is better. In your case, I would like it stand for 2 days.
7. Completely drain the system by flushing the faucets for several minutes each. Open the fresh water tank drain valve to speed up emptying the tank, If so equipped, open the hot water tank drain plug and drain until it is empty.
8. Close all valves and faucets and drain plugs.
9. Fill water tank with fresh water.
10. Flush each faucet for several minutes each repeating until the tank is again empty. (Again, make sure you are using the water pump and not an external water supply.)
11. Fill the tank again. The water should now be safe to drink but if the chlorine odor is too strong you can repeat the fresh water flush.
12. Your fresh water system should now be safe for use, and the mildew smell should be completely gone.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
