Old 09-28-2016, 02:02 PM   #1
Can't fill fresh tank all of the way
Hi All,
I recently had a need to use my fresh tank for the first time and ran in to a problem. When the tank was a little over half full, water started coming out of the overflow. Even after I stopped filling the tank, water continued from the overflow, almost as if it were siphoning from the tank. I eventually lost about half of the water. Does anyone know how the overflow is connected to the tank? Is it just inserted in to the tank through a hole, possibly too far resulting in my problem? Can I put a valve on the overflow line or is it also used as a vent? Even better, is there some sort of backflow preventer I could install?
Thanks,
Rob
2015 Wildwood X-Lite 281QBXL
2009 GMC Sierra 1500 Z71 w/HD cooling
helirob is offline   Reply With Quote
Old 09-28-2016, 02:05 PM   #2
Sounds like it might not be vented properly. Still under warranty ???
...VTX-Al
VTX Al is offline   Reply With Quote
Old 09-28-2016, 02:34 PM   #3
If your Wildwood is like mine there is no overflow but there is a vent. It is a 1/2 inch hose from the top of the tank to a small vent hole next to the fill cap. Mine was crimped where it exited the tank. When I filled the tank it would build up air pressure and then blow water back out of the fill hose. The fix was to install a 90 degree elbow to remove the crimp.
Cedar Creek Lake, Texas
2016 Wildwood Xlite 171 RBXL
2016 Ram 5.7L crewcab.
CedarCreekWoody is offline   Reply With Quote
Old 09-28-2016, 02:56 PM   #4
Al, That's what I'm thinking. Maybe the vent tube is inserted too low in to the tank. It would explain what I'm seeing. The question is, what's involved to reposition the tube. It's not under warranty anymore, so I'm on my own.
Woody, there is no vent on my fill cap. There's a hole, but it's not connected to anything. This leads me to wonder if the overflow is also the vent.
Old 09-28-2016, 05:44 PM   #5
That sounds like the vent tube, but laying loose. Follow it and see if you can
Old 09-29-2016, 03:22 PM   #6
I have a 2016 wildwood heritage glen that I am taking back to the dealer to fix deficiencies. I have the same problem with my fresh water tank, but it only fills 1/3 before it starts to overflow out the hose coming out the bottom of the tank. while on vacation, we called the dealer and he suggested that ther might be water in the line that is just being pushed out.. his suggestion was to keep filling until the inside meter said Full. even though ti may be emptying out the bottom. So, we did as they recommended. Once it hit full, we turned off the tap and the over flow continued to drain until the the meter said 1/3 full..
we think the overflow drain connection might have been installed too low on the tank or the the overflow hose is 2/3 into the tank and is acting a siphon. In 2 weeks the dealer will have to drop the belly pan and take a look at it...
Jeff from Burlington Ont is offline   Reply With Quote
Old 09-29-2016, 03:45 PM   #7
Jeff, That sounds exactly like mine. I'm curious to know how they fix this. Can you post an update afterwards?
Old 09-29-2016, 03:47 PM   #8
Does anyone know if I can put a valve on the overflow?
Old 09-29-2016, 04:06 PM   #9
Berkshire 390QS
NO3putt's Avatar
Your really need a vent from the tank so you won't build up too much presure when filling. Think what I would do is install a new vent by drilling a new hole and sealing a new vent on tank and closing off the old one. Sounds like your tube has been installed too low to me.
2015: 188 days, 2016: 72 days,
Skip
Old 09-29-2016, 04:18 PM   #10
No3Putt - that's a very good idea. I will do that.
tank
» Massachusetts Campgrounds
