03-19-2016, 04:20 PM
Can't get anode rod in
I removed my anode rod last fall and attempted to put in a new one today. It won't thread all the way in. There is some white substance in the inner threads, probably the sealant used instead of the tape. Any suggestions on how to remove it?
03-19-2016, 04:27 PM
The Anode is a pipe fitting and will not (and does not need to) go all the way in.
The anode just needs to be tightened just enough to be watertight.
Use a wire brush to clean the rust off the threads and using Teflon Tape (or Teflon white pipe dope - its OK), put a couple of wraps of tape over the anodes threads.
Tighten snug (DO NOT crank it in! - you will never get it back out).
If it leaks (it should not) you can give it another 1/4 turn to stop it from leaking.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
03-19-2016, 04:28 PM
what do you mean it won't thread all the way in? You won't make all the threads go in. It's pipe thread, so it has a taper too it. You will get about half or a little more of the threads in.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-19-2016, 05:09 PM
What size tap would I need to tap the hole for the anode?
03-19-2016, 05:13 PM
3/4" NPT, but I would not use it to do anything but clean the threads. DO NOT start cutting threads (removing steel).
03-19-2016, 05:14 PM
Thanks OC
03-19-2016, 05:16 PM
A thread chaser might be a better option.
3/4-inch NPT
03-19-2016, 05:17 PM
My trick is put some faucet grease on the anode threads and screw it in and out by hand a couple times until it goes in easy. Then I wipe it off, put the pipe tape on it and screw it in permanently.
2009 FreeLander - Retired
2015 FR3 30DS - Retired
2023 Sunseeker 2440DS
Towing 2016 Chevy Sonic LT
03-20-2016, 01:34 PM
Thanks everyone, it is in and I was able to finish de-winterizing.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
03-20-2016, 07:16 PM
I'm jealous. I've got another month before I can even dream of de-winterizing! Glad it worked out.
Joe & Sue - Camp Mutt Duke
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
03-20-2016, 07:33 PM
The white buildup I found on mine is Calcium buildup in the threads which were previously exposed to the tank water. I cleaned some of it out, but like everyone has said, the anode won't thread all the way in. I use teflon tape to seal and never leak a drop.
03-22-2016, 03:27 PM
As for the "white substance" it is most likely calcium from the water, and if it has became hard, the only way to properly clean it out is with a pipe tap, that will re-thread the threads and also clean out the pipe dope and the calcium build up in the back threads.
I have had a tap for this purpose for many years and every spring just run the tap up the treads and i am good to go with a new anode rod.
Hope this helps and Happy camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
