Old 03-02-2018, 12:13 PM   #1
Changing cable on Bristol valve
I donít know if this has been mentioned here but I replaced the cable on one of my gray water tanks with a Valterra cable. The old stranded cable had frayed at the handle and was routed Wrong. I thought Iíd post this because I read somewhere that this couldnít be done.
Rbare31 is offline   Reply With Quote
Old 03-03-2018, 09:13 AM   #2
SeaDog's Avatar
How about letting the forum know the steps you took to replace the cable, where you got the replacement etc. maybe a pic or two so that others can learn from your experience.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 03-03-2018, 09:44 AM   #3
I added this fact to the forum because I searched for this answer and couldn’t find any info. It’s pretty straight forward. I don’t have any pictures but I just took the cable out of the old valve and replaced it with the new cable the same way the old cable was attached. I cut off about 1/2” of the solid inner core and changed the black handle with a gray one I ordered. I had to drive out a roll pin from the black one to remove it. I ordered both of them off of eBay. I did have to remove the wall beside the wet bay to get access.
cable, valve
