Old 06-25-2016, 05:55 AM   #1
strut526's Avatar
Changing or bypassing inside water filter. .
How do I shut off the water to the inside filter canister? I bought a new filter, to change the old one out. And is it possible to just bypass that filter all together and just use the outside water filter?
2005 American Sport -Went seasonal 2012 Irish Hills, Michigan
strut526 is offline   Reply With Quote
Old 06-25-2016, 05:59 AM   #2
fonzie's Avatar
Disconnect from city water, make sure water pump is off, relieve pressure by opening one faucet and then change filter. Yes you can by-pass filter, see below....
Water filter bypass
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-25-2016, 06:03 AM   #3
strut526's Avatar
Thanks for the quick response. I will try to change the filter out. I have watched my husband do it, but didn't pay close enough attention, and he's not here. Have low water pressure inside the camper, and thought they needed changing. I disconnected the city water hose, to check flow and it was fine.
Old 07-08-2016, 08:55 AM   #4
strut526's Avatar
Update: changed the inside water filter, and now have water pressure like I should. Thanks for all the responses and ideas! I am going to switch to an outside filter, like 5picker, showed in the picture. All is well, on with camping in Brooklyn, Mi.
bypass, water, water filter
