Old 05-19-2013, 06:46 PM   #1
Changing Water Filter
I just purchased a 2014 Rockwood 2905SS. Installing the water filter was a pain. They charged the water system to show me how everything worked but left the filter out so they were not wasting it they said.Does anyone have a better system for changing it, there is no drain so water spills everytime you have to do it.Once a year may not be alot but I would have thought there would be a better way.Thanks in advance for any help.
Vinchenzzi is offline   Reply With Quote
Old 05-19-2013, 06:48 PM   #2
TURBS's Avatar
I put a coffee can under mine when changing.
I've thought about installing a petcock at the bottom tho.
Hmmmmmm thanks for reminding me.
Old 05-19-2013, 06:50 PM   #3
treaves's Avatar
No, that's it. My unit has the filer in the hookups areas, which has a hole where the hoses come up through, that can act as a drain, so no big deal. Works the same in a house.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 05-19-2013, 06:52 PM   #4
TURBS's Avatar
This.
Name:	1333652299wilkerson manual pet cock drain_grp-95-182_color_lg_watermarked-1.jpg
Old 05-19-2013, 06:53 PM   #5
treaves's Avatar
Those wont help at all. You simply depressurize the system by opening a faucet with the water pump off. But even once that is done, you will get a cup or more of water out when you change it.
2014 Columbus 320RS
Old 05-19-2013, 06:55 PM   #6
QCCowboy's Avatar
Similar to Turbs, I usually just grab one of our throw away Tupperware containers to put under it, then open slowly. I use a blow out valve (similar to winterizing) and get a little bit of water out of it first which does help.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 05-19-2013, 06:55 PM   #7
TURBS's Avatar
What do you mean it won't help?
This will drain the entire filter assembly.
He probably doesn't want water all over the floor if its in a tight location.
Of course you have to relive the pressure before removing bowl.
This petcock would drain it.
Turbs
Old 05-19-2013, 06:59 PM   #8
TURBS's Avatar
At the bottom of this
Old 05-19-2013, 07:05 PM   #9
treaves's Avatar
O.K., it may help some. But it will still spill water, from the line, as well as the unit itself. So even though it will drain some of the water, as you still are going to spill water, it's of dubious value.
2014 Columbus 320RS
Old 05-19-2013, 07:15 PM   #10
I use a garbage bag in a coffee can and don't get water on anything. Just slip the bag up, slide the can under the canister with the bag over the canister and un-screw it. No pain, no strain and no water anywhere except in the bag and the can.
accumulator, water filter
