Old 10-17-2018, 06:38 PM   #1
Chaparral fresh water drain
I just bought a 2015 Chaparral fifth wheel 345BHS and I have not been able to find a fresh water drain valve. I found a blue line with a cap on it underneath but all my other campers had a valve so I am not sure if there is water in it. Also there are 2 white open ended drain type lines with no caps or valves and I am not sure what they do. I only see one line that must go to fresh water tank and I am assuming it fills the tank and also it's the suction line for pump. I wish it had a plumbing diagram so I new my winterizing was complete.
Thanson is offline   Reply With Quote
Old 10-17-2018, 06:42 PM   #2
Assuming they are all grouped together the capped pipe is the fresh water drain and the one or two uncapped lines are fresh water tank overfill drains.
I cut the cap fitting and put this valve on.
BestPEX 51249 Metal Chrome 1/4 Turn Straight Valve, 0.5" Size https://www.amazon.com/dp/B002Z9B6U2..._5K8XBbBCHD5CM
This valve is better suited if you donít have a pex crimp tool. I have used both and they work great.
Flair-It 16880 Plastic Straight Stop Valve, 0.5" Size https://www.amazon.com/dp/B000BOKOUQ..._PL8XBb007GXP3
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
drain, fresh water, water
