Old 09-30-2014, 06:25 AM   #1
Geaux_Jeaux's Avatar
Check valve columbus 320rs
Wife and I picked up our new 2015 columbus 320rs last weekend. We took it out for a one night stay. After trying to flush out black tank noticed no water going into tank. Have read in other threads check valve my have been installed backwards,
Questions are where's the check valve located? And dealship is about 50 miles away, Should I bring it back or change it myself?
Thanks for everyones help with this
Geaux_Jeaux is offline   Reply With Quote
Old 09-30-2014, 06:32 AM   #2
TURBS's Avatar
Check valve could also just be stuck.
It's right where you hook up the hose.
Pretty easy to get to.
My money is stuck.
Turbs
Old 09-30-2014, 06:42 AM   #3
They (Valve) are normally directly behind the (Garden hose hookup).The Pex goes (Up) the wall to the valve then returns (Down) thru the floor into the tank. Most of the time in a Very (Inconvenient Location)! Youroo!!
Old 10-20-2014, 08:43 AM   #4
It's the check valve. Picked mine up last weekend after having the same trouble. Dealer had 3 in at the same time for this ptoblem
kssportsman is offline   Reply With Quote
Old 10-28-2014, 03:47 PM   #5
Thanks for the replies
Picked up from dealer earlier this week. The person that worked on the trailer stated whoever put the black tank flush line in ran it between the plywood floor and frame, figure that one out no wonder water wasn't going in.
It's fixed now and ready to geaux, if you know want I mean
Will try it out this weekend
320rs, columbus
