Old 03-18-2015, 09:51 AM   #1
iluvlcy's Avatar
Check valve on black tank rinser
While dumping this trip when we turned on rinser, water started coming out around the underbelly. Could this be a check valve problem?
The water was clean so pretty sure it was the rinser, no problems when we dumped grey tank earlier in week. Do we need to drop the underbelly to dry? Can we replace ck valve ourselves? Do we need a ck valve?
Thanks for any help
Pam
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 03-18-2015, 10:00 AM   #2
Campfire Master
The check valve is usually up high, under the bathroom sink, etc. If it was leaking, I would imagine that you would have a mess inside somewhere. Sounds like it's leaking from fitting into the tank.
John
AVid is offline   Reply With Quote
Old 03-18-2015, 10:31 AM   #3
Thanks for any help.Pam
The check valve is on the back of the hose connection inlet to prevent water from returning to the supply hose.
The vent is usually mounted higher up under the bathroom vanity. They are also noted for leaking, I removed mine completely and routed the inlet directly to the tank.
Old 03-18-2015, 10:42 AM   #4
bubbles's Avatar
Typically, there is no check valve as you describe for a black tank cleanout. There is a backflow valve (check valve) in series with the tubing installed within the unit (higher than the black tank) as you said. That is why when the hose is disconnected from the clean out port the residual water in the tubing from the check valve (input side) will come out the port. It's fresh water.
Old 03-18-2015, 10:44 AM   #5
geotex1's Avatar
Thanks for any help
Pam
Sounds more like the fitting for the rinser is loose or has broken at the tank. You're going to need to drop the underbelly and have a look.
geotex1 is offline   Reply With Quote
Old 03-18-2015, 10:56 AM   #6
The inlet water on mine went thru the backflow preventer up under the bathroom vanity to a plastic vent/check valve and then down into the black tank. As I said, I removed the vent/check valve and ran directly into the tank. Mine was leaking down into the basement and out on the ground.
Old 03-18-2015, 02:26 PM   #7
beechjr's Avatar
Black tank rinser
Mine was leaking in basement when rinsing black water tank. It was actually the fitting going into tank was crack from being over tightened at factory! Had to take apart and reseal fitting with a 2 part bonding epoxy to stop, or take back to dealership, which was not a option. Good luck
2013 Forest River Blue Ridge 3025RL
2005 Chevy 3500 Crew Cab Duramax
beechjr is offline   Reply With Quote
Old 03-19-2015, 09:52 AM   #8
I had that problem it was under warranty the line was pic it was leaking in my water heater compartment they pulled the water heater and fixed the line with a flex line so it would give while there is movement camping now used it the other day works great no leaks good luck.
Grouch1
2013 Georgetown 351dsf
2011 Jeep Wrangler
Grouch1 is offline   Reply With Quote
Old 03-19-2015, 09:54 AM   #9
I ment to say pvc line sorry
Grouch1
2011 Jeep Wrangler
black, black tank, tank
