Old 04-09-2019, 07:46 AM   #1
TsnTexas's Avatar
Check valve on water pump?
Interesting problem popped up on our last camping trip. We were hooked up to electric and water for a couple of days when suddenly our fresh water tank started filling up and then overflowed. This had to come through the system which was hooked to the campground water supply. This is on a two year old Rockwood 2504s, isn't there a back flow preventor or check valve somewhere?
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 04-09-2019, 07:55 AM   #2
cavie's Avatar
Yes. Check valve is in the pump.Try this. Turn city water off. turn on your pump on open a faucet and run some water. Turn pump off. Repeat the process. Turn pump off and turn city back on. This should clear your backflow valve. This happens when people turn the pump on with city water pressure on it. If the check valve is still faulty all you need is a rebuild kit. Easy to do. Amazon is your friend.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 04-09-2019, 07:58 AM   #3
That is my understanding.... either just beyond the pump on tank water side or I have heard some say that it is built into pump on some now.
gbaldwin is offline   Reply With Quote
Old 04-09-2019, 08:04 AM   #4
It has always been built into the head of the pump.
It is only not in the pump when someone mods the plumbing and adds a check valve.
The valve sticking from debris or being overcome by too high city pressure is a common topic and discussed here at least twice weekly.
Here is a search to past discussions. There are thousands of posts.
Fresh tank fills on city water.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 04-09-2019, 03:48 PM   #5
This has happened to me several times. Solved by installing a check valve on the output side of the pump. Tried it on the suction side but had some issues.
RStormC is offline   Reply With Quote
Old 04-10-2019, 06:39 AM   #6
Check valve
X2
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
Handydc is offline   Reply With Quote
Old 04-10-2019, 07:24 AM   #7
TsnTexas's Avatar
Thanks guys, I'll rebuild or replace the pump head and look for an in-line check valve. Which check valve did you wind up using? I see several on amazon, but the reviews for those aren't great.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 04-10-2019, 09:55 AM   #8
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Why would you not try the suggestion that cavie wrote about recycling the pump before buying parts and repairing something that might not even be broke? I've had what you have going on at least three times on two rv's and the recycle instruction has worked each time.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 04-11-2019, 06:30 AM   #9
TsnTexas's Avatar
That's a good point, because I didn't turn the pump on during the time I had water hooked up to campground supply (as he mentioned) I feel I can no longer trust the check valve in the pump. At the very least I want to add a check valve in the water line because the mishap strained my fresh water tank. Thankfully it didn't split open. Besides it's so much easier to make repairs at home before hitting the road.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 04-11-2019, 07:10 AM   #10
Denver To Yuma In 90 Days
When mine failed I opted to put a check valve in line instead of fixing or replacing the pump since the pump's built in check valve will probably just fail again.
You can get the Camco brass check valve for under $15 and takes less than five minutes to install...no tools needed!
And will probably last as long as you own your RV.
I put mine right in front of the water pump and has worked great for a year now.
ID:	201424   Click image for larger version
ID:	201425   Click image for larger version
Someone "doing it for years with no problems" doesn't mean YOU should!
2015 Heartland Prowler P292 5'ver, Reese 16K Pro Slider Hitch
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear end
JohnD10 is online now   Reply With Quote
check, pump, valve, water, water pump
