Old 01-15-2018, 04:54 PM   #1
City water and fresh water tank.
I noticed while on our camping trip this weekend that water was dripping out my fresh water tank overflow tubes. Strange, considering that there was no water in my FW tank. Or, at least I thought so.
Checking the control panel, it showed my FW tank completely full. Strange, since I did not put any water in it.
I drained the FW tank and afterwards noticed that there is a small flow of water coming out the FW drain tube as long as I had my city water on.
So, I am assuming there is some kind of mutual connection between the FW water tank and the city water connection? Considering both have to send water to the RV faucets. I am thinking there is some kind of check valve/ball that is suppose to keep the city water from flowing into the FW tank?
Thanks,
2016 Heritage Glen 272RLS
2017 Dodge Ram 2500 Big Horn, 6.7 CTD, 4x4
KRSmitty is offline   Reply With Quote
Old 01-15-2018, 05:07 PM   #2
fonzie's Avatar
Check valve in water is leaking, see thread for fix....
check valve in water pump system
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 01-17-2018, 02:17 PM   #3
Anyone able to tell me where the pump may be located/access point on a 2016 Heritage Glen?
Old 01-17-2018, 04:58 PM   #4
bikendan's Avatar
Since you're asking for model-specific information and not General type information, I suggest you start a thread in the Wildwood sub-forum, where most Heritage Glen owners are.
There is no standard location for water pumps. They vary wildly between brands and models.
Equalizer WDH
Old 01-17-2018, 05:00 PM   #5
Mr. Dan's Avatar
Does this mean Fonzie's suggestion in post #2 didn't work for you?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 01-17-2018, 05:48 PM   #6
Nope...just being a little proactive. Where I store my RV is a few miles from the house. Getting all the info I can before I head out to work on it.
Old 01-17-2018, 06:05 PM   #7
Mr. Dan's Avatar
I was just asking since that solution hasnít always worked for some of us. Uncle Geneís water pump had a wrinkled o-ring around its anti reversing valve.
Old 01-17-2018, 06:12 PM   #8
fonzie's Avatar
If no one tells you where pump is, then start your pump and listen for it through out the trailer. Then you will have to access it through a door, a removable panel, from an outside storage access etc etc.....
Fonzie
Old 01-17-2018, 06:19 PM   #9
Open a faucet to force pump to run while you are looking for it.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 01-18-2018, 03:52 PM   #10
Water Pump location
On my 2017 Heritage Glen the pump is located immediately behind the panel that houses the City Water input connection, hot water heater bypass valve and black water tank flush water input connection. Note: the hose that sticks out that takes a suction on the anti-freeze containers connects directly to the water pump.
JimHG65101 is offline   Reply With Quote
city water, fresh water, tank, water, water tank
