01-17-2020, 03:46 PM
City Water Connection
Looking for how people hook up the city water to their TT's. With our brand new trailer I am probably over thinking this but I have two questions:
Regulator Placement:
- At the spicket?
- At the the TT?
Hose connection:
- What do you do to take the tension from the hose off the TT?
- elbow?
Firm believer in the stupidest question is the one you do not ask.
TIA
2020 Forest River Flagstaff Micro Lite 21FBRS
2018 RAM 1500 4x4 Laramie EcoDeisel
01-17-2020, 03:49 PM
At the spigot will help protect the hose also.
At the hose connections use one of these:
https://www.amazon.com/Camco-Degree-...9294157&sr=8-4
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
01-17-2020, 03:52 PM
Originally Posted by Kcoulter
Bingo!!
01-17-2020, 04:48 PM
water.
Same part can be had wally or lowes. Originally I had the internal water filter. Then I changed to using the "blue tube". The setup I went with was from the rv to the elbow, elbow to a short hose that reached the bumper (the strain relief issue), water press reg, filter, cut off, then ahose to the camp water feed.
I have since moved my press reg internally, but I still use the setup less the reg. A couple of benefits, the hose on the ground is the only hose dirty, and only two hook ups each set up as I leave the bumper to rv line together as a set. Since I no longer use the press reg externally I empty the short hose, filter, shut off, and put the whole rig in the frezzer btw trips. Cuts down on bactria growth.
See ya out there....
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
01-17-2020, 05:49 PM
Same here, but really in the grand scheme of things it will work the same by just screwing the hose in to the trailer will last probably just as long. Last hose I bought was $10. Last summer.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-17-2020, 06:05 PM
Regulator placement... at the campground spigot. Just remember to take it with you when you disconnect.
Tension on the hose... use the elbow recommended above
Also, we use a y-adapter at the spigot so that we can connect the garden hose we use to clean out the sewer hose.
There are no stupid questions on this forum, although there have been a few questionable answers.
2015 Dynamax REV 24TB class C
01-17-2020, 06:15 PM
Always Learning
Back when I had a water bay, I mounted the regulator in there and would quick connect my hose onto and off of it. It meant that I could never forget it at the campsite. I accepted that my hose was at risk for the convenience of not forgetting it.
Now I have it permanently mounted on the output side of my water filter system. It's a big bastard and I won't likely forget it!
01-17-2020, 06:26 PM
I use an adjustable water pressure regulator at the spigot. and a brass 90* fitting at the rig.
Retired Navy
2016 Flagstaff 26 FKWS
01-17-2020, 07:37 PM
I use hose wye,on one side we just have a hose for the fire pit, full pressure on that side, on the other, a Watts regulator at the faucet, then GE filter, then short hose into 90 in water bay.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
01-17-2020, 07:57 PM
at the trailer we use the Camco Water Diverter, a convenient way to connect city water similar as show above, but also provides an additional faucet outside the RV, ...
https://www.amazon.com/Camco-22475-W...%2C157&sr=8-12
01-17-2020, 08:05 PM
in over 5 years and over 100,000 miles in the continental U.S., Alaska, and most all provinces in Canada, I've never used any 'water pressure regulator' or similar device, unless I was at a few campsites that had one already installed permanently on the spigot - never had 'issues' with water pressure being 'too high' - though there seem to be quite a bit of conversation around whether these actually cause a 'lack' of pressure.
Using one doesn't present any 'problems', maybe, but not using one also doesn't either.
enjoy!
The Turners...
01-17-2020, 08:18 PM
As you have seen on the forum some people think that they are right no matter what even though they are not. It is their way or no way.
Bottom line for you is a hose and a pressure regulator are minimum and fine to use alone. But........... there are many good suggestions here.
The elbows are a great idea but if you do not have them no big deal and I do usually use one.
ependydad has a great system but he and his family full time and I would do the same if I full timed. Doug always has a lot of great advice.
1966 Mustang GT
1986 Mustang SVO
