Old 05-28-2012, 06:38 AM   #1
thaithco's Avatar
City Water Connection
Bought a new-to-me HW252. The guy before didn't winterize so I've been fixing water leaks. I was surprised to find that the city water main connection was plumbed in 1/4" PEX. That seems odd since the remainder of the camper is in 1/2" PEX. I don't seem to have water pressure issues at the sink but the outdoor shower is very low. Should I change out the 1/4" to 1/2? Or is there some other reason it's 1/4"
thaithco is offline   Reply With Quote
Old 05-28-2012, 08:19 AM   #2
I would change it to 1/2 inch. Should have been that way from the factory. They only use 1/2 inch, so someone must have repaired it with what they had. That way, if you ever have a problem, and need a repair, you know it is all the same size, and uses the same crimp rings and crimp tool.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
