Old 02-12-2014, 10:07 AM   #11
bubbles's Avatar
Backflow to the fresh water holding tank is accomplished by baffles within the head assembly of the water pump.
Old 02-12-2014, 10:24 AM   #12
onetonford's Avatar
It can only be coming thru the water pump which has two check valves in it they can be repaired if your handy they sell kits for them.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 02-12-2014, 10:33 AM   #13
bubbles's Avatar
Sometimes if the pump is run with city water pressure present the silicone baffles in the pump turn under and not prevent backflow. The pump head can be taken apart easily to check for this and as stated there are kits to repair if needed. All water pressure including holding tank contents should be withdrawn to pull the pump out.
Old 02-12-2014, 10:40 AM   #14
MtnGuy's Avatar
Another idea is turn off the city water, and then turn on the fresh water pump a couple of times, and let the water run through a couple of faucets to get a good flow. If there is some restriction keeping the anti-back-flow valve from closing all of the way, that could flush whatever is there out of the valve.
Old 02-12-2014, 10:44 AM   #15
Witch Doctor's Avatar
As stated above your city water go's thru your 12 volt pump. By the time you pull the pump and buy the parts, I would just buy a new surflo pump, they are pretty cheap. I tried to rebuild one and ended up putting in a new one anyway was never the same. Just match the model numbers or count your fixtures that's how they size your pump.
Coachmen M/H
Concord
2018 / 300 DSC
Old 02-12-2014, 10:51 AM   #16
There are (2) posts for the same issue going at the same time? I posted a notice but it is still there! Youroo!!
Old 02-12-2014, 10:55 AM   #17
Triguy's Avatar
The two threads have been merged into this one to keep it all in one place.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-12-2014, 11:01 AM   #18
I agree with Glen! Youroo!!
Old 02-12-2014, 11:16 AM   #19
Brother Les's Avatar
Sorry, I don't agree with Glen at this time.
The water pump is (as is the unit) too new to really have any parts worn out. There is an obstruction problem. Take the water pump apart and remove the obstruction. A 100 dollars for a new water pump is not all that expensive or that cheap.... If a piece of calcium gets stuck in the back flow and there is more calcium in the water line..... you replace the pump with a new one and that calcium moves into the new pump and you have the same problem. Stuck back flow valve. Take the one apart on your unit and learn how it works. If you can fix it in a few minutes, you have learned a major lesson. All is good. There will come a day when this will happen again and Camping World will not be down the street to grab a new pump. My motto is that I will learn how to 'fix it or it will be so broke that it can never be fixed'. I have learned to fix a lot of stuff along the way to breaking a lot of stuff. I now know on most things when to reach for the tool box or the Telephone.
Brother Les
Old 02-12-2014, 11:24 AM   #20
BigTJohn's Avatar
Running the pump for a bit will probably do the trick. Most of us never use the onboard system to give it enough of a workout. This happened to my boats several times and just running the pump worked each time. I make it monthly thing to run the pump and ensure it works as it should. None of my RVs have had a pump problem since.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
tank, water, water tank
