Old 08-19-2010, 06:59 AM   #1
JAD
Red face City Water hookup
Having serious trouble with water connection. Spray from hose connection is teriffic. Any suggestions?
JAD is offline   Reply With Quote
Old 08-19-2010, 07:09 AM   #2
Herk7769's Avatar
Sounds like you need a gasket.
Most likely the old one fell out at some point or it is collapsed to the point where its not sealing.
I needed 2 gaskets on my black water flush turbo port to make enough room for the check valve I put on the hose to keep it from leaking.
HAM CALLSIGN - KC3FFW
Old 08-19-2010, 07:27 AM   #3
skeeterbait8's Avatar
I agree..... sounds like gasket problems. Either it is gone, or maybe not slid up as far as it needs to be.
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 08-19-2010, 07:46 AM   #4
camping
tentcamper1's Avatar
get the gasket with the screen. thats all I will use for filling the fw tank or if at a site with water. I found pipe dope in it from one campground, and I always let the water run before hooking up. seems like there is always some debris in the screen.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-19-2010, 08:28 AM   #5
Iggy's Avatar
Totally agree with this statement.
ALWAYS run water thru the hose before hooking up to the trailer so any garbage will flow out as well as any old nasty waster left from last trip in the hose.
Old 08-19-2010, 12:03 PM   #6
JAD
Leaking water input
Thanks for the inputs. Had already replaced the washer, even doubled up and this did not work. I am now running without any washer and the leak is considerable reduced. I am considering some teflon tape now to see if I can eliminate the slight leak. Does anyone know if there is a brass replacement for the fitting on the RV?
Old 08-19-2010, 12:17 PM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
Take your pick there are plenty types available. I bought one here, they're close to my house but they ship anywhere. Or just use it for a reference.
Reicharts Camping Center Online Store
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 08-19-2010, 12:35 PM   #8
Herk7769's Avatar
Leaking inside or outside trailer?
Old 08-19-2010, 06:08 PM   #9
milzat's Avatar
Some likely a bad city water inlet.
I've had two factory inlets go bad. I replaced them with a B&B brand, part # 160 85 A26. No mo leaking.
milzat is offline   Reply With Quote
