Old 04-27-2014, 07:54 PM   #1
Frankie Z's Avatar
City Water leak
Went camping this weekend, first time for 2014 Sunseeker 2650. Connected to city water hookup, pressure regulator on campsite water hookup, camco filter with flex hose on end attached to city water inlet. Water inside on floor at foot of the bed inside the wall where city water hookup is. Any suggestions as to a quick fix or is this a return to dealer warranty issue? I could find no leaks inside the RV, just water on the bedroom carpeting.
Thanks,
Frankie Z is offline   Reply With Quote
Old 04-27-2014, 08:04 PM   #2
Average Joe
MrJoe's Avatar
Shouldn't be leaking inside the RV. Sounds like a trip to the shop?
Was the connection outside leaking? If so, try the elbow... see pic
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 04-27-2014, 08:06 PM   #3
Frankie Z's Avatar
I actually had an elbow on and no, no leaking on outside.
Thanks for responding
Old 04-28-2014, 10:14 AM   #4
Same problem - hose that attaches to outside fitting leaking -
Typically they use compression fittings - Have switched mine to shark bite fittings.
cadman99 is offline   Reply With Quote
Old 04-28-2014, 10:24 AM   #5
Frankie Z's Avatar
Were you able to repair from the outside of the rv?. I do not have access inside.
leak, water, water leak
