Old 04-18-2018, 07:54 PM   #1
City Water Overflows?
Good evening all! Glad to have found this forum. I have a problem with my water system. When I hook up fresh water(under pressure), it constantly overflows from underneith the trailer. It didnt do this at first. One morning there was water running out from under the trailer. At this point, i can only use water from my holding tank. Please help. Any advice would be appreciated.
Huntxtrm is offline   Reply With Quote
Old 04-18-2018, 08:01 PM   #2
Flybob's Avatar
Easy solution.
If you have your water pump on when you are connected to city water the reverse flow valve can seat incorrectly. To fix this do the following.
Shut off city water at pedestal
Make sure water pump is off
Open faucet and let flow until water stops.
Close faucet
Turn water pump and allow it to run until it stops
Open faucet and allow water to run for 30 sec
shut off faucet
Turn off water pump
turn water back on at pedestal.
You should be ok
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-18-2018, 08:14 PM   #3
Denver To Yuma In 90 Days
Originally Posted by Flybob View Post
Easy solution.
Close faucet
shut off faucet
Turn off water pump
You should be ok
I just had that same problem and none of that stuff worked...
Basically what is going on is the water pumps built-in check valve is no longer working and the city water is flowing backward through the water pump and filling up the fresh tank.
I put a new check valve in front of the water pump and now no more fresh water tank overflow!
I change the screen as well...each part was $15 at a local RV parts store!
I have photos...I'll post them a little later.
JohnD10 is offline   Reply With Quote
Old 04-18-2018, 08:18 PM   #4
After doing what Flybob suggested, make sure you are using a quality water pressure regulator.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 04-19-2018, 05:52 AM   #5
Thanks All! I will check that out this weekend, and see if it works for me. Looking forward to those pictures.
Old 05-05-2018, 04:21 PM   #6
Swhitesell's Avatar
Photos would be awesome. I tried flybobs fix and it seems to be working. But I'm still nervous about it. It took about 12 hours for the over flow t happen. Only been 4 since I did the routine.
Swhitesell is offline   Reply With Quote
Old 05-05-2018, 04:22 PM   #7
Swhitesell's Avatar
I do have a good regulator. After the reading I have done here today, I will have a spare next time out.
city water, water
