Old 08-05-2012, 01:26 PM   #11
BigTJohn's Avatar
"Now change topic sort of-- I'm using one of these hex socket adapters
from harbor freight
3 Piece Hex Drill Socket Drivers
and a 3/4 el cheapo socket to run my jacks via craftsman battery drill.
This combination works OK but it's 2 piece so every once in a while the
socket goes missing---- I usually find it hanging on the last jack I used
it on
I wouldn't mind having one of these one piece driver sockets to do the job.
Camco 57363 Amazon.com: Camco 57363 Leveling Scissor Jack Socket: Automotive"
You can try epoxy and it will not release from the adapter/socket. It may, after some time come loose, but for a few cents of epoxy just reglue it.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 08-05-2012, 01:52 PM   #12
jimh's Avatar
i had to replace my rubber caps 2 yrs after getting the trailer. the nylon screw in has been there for the past 8 yrs.
jimh is offline   Reply With Quote
Old 08-05-2012, 07:16 PM   #13
Originally Posted by KyDan View Post
I'm a gardener and have various combinations of hose watering timers and
tons of drip irrigation and hose end repair pieces etc etc.... I've found hose
caps-- that screw on the male end of a hose but have not seen the opposite
sex. I need- we all need a male hose plug. Those are not found in the
garden hose accessory isle of WalMart or my local hardware store.
Where did you find yours??
Dan,sorry to hear you have not seen the (Opposite Sex)! My male nylon plug came from (Food supply barrels). They throw them away,no reuse on food barrels. Youroo!!
Old 08-05-2012, 07:40 PM   #14
vasnipe's Avatar
Blowout plug
I use the Camco blowout plug. Double duty, keeps the crud out and then when winter rolls around it does it real job.
Chris in Virginia
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
