Old 05-13-2012, 07:28 AM   #11
Triguy's Avatar
Originally Posted by PrimalScream View Post
ok, after looking again at my system, there are no check valves in it... :-(
The check valve is hard to see.
Rather than repost instructions, take a look at this thread. Post 7 by Herk describes how to access it and confirm that it's operating correctly.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-13-2012, 08:13 AM   #12
Herk7769's Avatar
The check valves are there but they are internal to the water sources.
The check valve on the water pump is INSIDE the water pump. It prevents city water from spinning the pump backwards and filling your fresh water tank.
The check valve on the city water connection is located inside the city water connection behind the screen. If your "carefully" remove the screen you will see a while plastic tab pointing at you. It is spring loaded and should move freely with no water pressure on it.
For completeness, there is also a check valve "in line" with the turbo flush, if installed. It is located under the bathroom sink in my 5th wheel.
That check valve prevents a full black tank from siphoning out the hose connection for the flusher.
Name:	Water and Sewer Diagram.gif
HAM CALLSIGN - KC3FFW
Old 05-13-2012, 01:43 PM   #13
caper's Avatar
Pictures of check valves on city water.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-14-2012, 07:31 AM   #14
ok, thank you all very much. It is currently raining out so we are at home, but when we get back out to the camper I will check these things out and give an update. Thanks again
PrimalScream is offline   Reply With Quote
Old 05-14-2012, 07:49 AM   #15
Herk7769's Avatar
We have an Ultra-Lite Signature series camper and everything that can be is plastic; including these check valves.
Old 05-18-2012, 01:11 PM   #16
ok, back out at the campground, i tore apart the city water inlet and found that not only was the screen totally clogged but the spring was stuck shut. A quick 20 minute repair and we're in business. Thanks everyone for their ideas...without it I might still be searching.
led pad
