Old 05-12-2012, 05:39 PM   #1
City Water Solved
This year we setup our 2006 Forest River Surveyor camper at a campground that is all year round. We have sewage and city water capabilities. When we hooked up the hose to the city water we got nothing at all, but the holding tank with the pressure pump works just fine. Is there a valve we need to turn to switch from the holding tank to the city water hookup? Any help would be greatly appreciated
PrimalScream is offline   Reply With Quote
Old 05-12-2012, 06:07 PM   #2
tracer2011's Avatar
This may sound like a stupid question but, before you hooked up your hose, did you see if that spiqot worked? the reason that I ask is that on my trailer, there is 2 ports to add water and the city water by-passes the holding tank and does not require the pump to deliver the water to my fixtures as the city water pressure does that. also, there is a screen on the port where you connect your hose to your trailer that may be full of debri that might need to be cleaned.
Kevin and Ellen Sandoval and Angus the Dog
GMC Sierra 3500 Duramax 6.6 Turbo Diesel / Allison Trans 4x4 Crew Cab extended bed
Tracer 2600rls TT
tracer2011 is offline   Reply With Quote
Old 05-12-2012, 06:12 PM   #3
Triguy's Avatar
Welcome to FRF!
First, were you using something to reduce the water pressure and, if so, is it working correctly?
I would next inspect the check valve in the city water connection. This is a spring loaded valve inside the inlet for city water. A broken valve can obstruct the flow of water.
Good luck.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-12-2012, 06:20 PM   #4
Ok, to best possibly answer....the screen for the city water inlet is free of debris and in good shape and the faucets do work with the pressure pump and holding tank. The one thing I did not know about was the spring loaded thing on the inside of the screen. I was inside the camper and my wife turned on the city water and i did hear a small thump. At first I thought and complained to her about giving it full pressure at once instead of slowly, but perhaps the thump was that spring loaded thing stuck. BUT once again, is their a diversion valve from the holding tank and the city water? and also i crawled all over and under the camper looking for a diversion valve and noticed no check valves installed
Old 05-12-2012, 06:27 PM   #5
Triguy's Avatar
There is no such valve in mine to allow for manually choosing city water or the fresh water tank.
Scott
2012 Shamrock 233S
Old 05-12-2012, 06:40 PM   #6
tracer2011's Avatar
I agree with Triguy about the pressure reducing fitting. I never hook up my water to the city without it. did you just hook your hose from the city to your trailer? that may be the problem. please reply so others can jump in to help you troubleshoot this as without looking at your system we only have your feedback.
Tracer 2600rls TT
Old 05-12-2012, 07:00 PM   #7
tracer2011's Avatar
I just re-read your last response I have never heard of a "diversion valve" on every trailer that I have seen there is either a city connection port to hook up a water hose or a fill port for your fresh water holding tank. There should never be a valve to switch between the two.
Tracer 2600rls TT
Old 05-12-2012, 07:30 PM   #8
caper's Avatar
There is a check valve on the city water hook up. It should be a one way valve that will let water in from the city hook up. When you are not on city water and using the fresh water tank it prevents water from exiting the trailer through the city hook up. As stated this valve might be broken and not allowing city water to enter the trailer. I had the same problem last year. Replaced valve and had good pressure in the trailer.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-13-2012, 06:56 AM   #9
ok, after looking again at my system, there are no check valves in it, the line goes from the city water port to the the water treatment canister in the bathroom, where the port comes in from outside, then t's off of that to the other parts of the camper. Also, to ask another question about the diversion valve...if there is no such valve, what is stopping the water system from constantly trying to draw from the holding tank and only drawing air if empty? Im sorry to be a pain but i bought the camper used and received no schematics or manuals with it. Oh, and one more thing about the question of reducing the city water pressure.....when we turned the water on, i had the wife turn it on at quarter full, then half, then all the water and at all stages we didnt get a single drop :-(
Old 05-13-2012, 07:15 AM   #10
davidjb's Avatar
the pump is pressure sensitive, city water pressure will prevent the pump from coming on. there is a check valve in the pump to prevent the city water from going through it.where you hook up your water hose to the trailer you should be able to see a button(brass plug) there, this prevents pump water to exit the city water connection maybe that is stuck
davidjb is offline   Reply With Quote
led pad
